Question about Sony KDL-32M3000 32 in. LCD Television
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
I have the Sony Bravia 32" Set (KDL-32M3000) connected to a Motorola DCH3416 HD DVR unit.
I have the DVR unit connected to the TV with an HDMI cable, and the TV is unable to show the "Normal" picture mode.
The only available screen formats are Wide, Wide Zoom and Full. Of these, none represent an HDTV signal to fit the screen appropriately.
When I access the TV's menu system, I cannot change to Normal. It's in the menu options, but that particular option is grayed out.
What options exist?
  • Anonymous Feb 09, 2009
    When I connected to the Comcast Cable HD signal box, the screen always has a black border on all four sides. I can select the zoom and normal picture features, but there is always a black border. The tv will not go to full screen.
  • 320 Answers
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Posted on Oct 19, 2008
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
I have a sony bravia kdl 37m3000. We have cable and the wide screen would not go away so we unplugged the cable to reset the tv. Now the cable and the tv comes on but no picture.
Make sure you change the input that the cable is coming in on, If you was watching in HD mode then you was using an HDMI or compontet hook up.Look on tv remote for Video input button to select the componet input 1 or 2 or HDMI inputs which it is connected to. Look for a button on the remote called TV/VIDEO or INPUT
Dec 15, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
I have a new Sony Bravia 32" TV and when the Verizon Cable was installed with HDMI connection, TV had sound but now picture; instead it gave me a green color. The same Cable was connected to another TV...
It is your BE2 Board, it has a problem, iv seen this befor, if it is brand new, i would call sony, they should send out a service center, and Sony will cover the repair
Jan 10, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KDL-32M3000 32 in. LCD Television Logo
1,022 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
