Back to:
Tags:
Mitsubishi VS-50605 50 in. Rear Projection Television
Tv problem
posted by ram16962 on Mar 05, 2008
imGE OUT LINE COLORS OF NOT LINEUP
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 28, 2008
Not Rated (0)
Slinteriors
Rank:Guru Guru
Rating: 88%, 2489 votes
replace both convergence ICs STK392-110 they are available at the following link and they give free installation instructions and free online tech support. The repair is easy and takes about 45 minutes from start to finish.
http://servicemanuals.vstore.ca/
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tv problem:
I don't want to Accept this solution
Can you Help with these Projection Televisions problems?
Mitsubishi VS-50605 50 in. Rear Projection...
Where can i get a service manual for this set. I'm pretty...
was watching the set the screen went dark then back to...
my tv screen is rolling when you turn on the tv....someone...
lighty fuzy picture some channels better than some
when the tv has been off for awhile, when i go to turn it...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
