Question about Kenmore 24032\24036 Top Load Washer
Water comeing out very slow
I have a top load kenmore washer and out of the blue when it fills the water barely comes out the modle number is 110.16602690. please help asap thank you
    Genius:
  • 3,587 Answers
Sounds like plugged pipe or an unhappy pump at bottom
Posted on Mar 05, 2008
Kenmore 1107672267576722 not filling nor washing
sounds like no water coming into washer?if you go to fill it do you hear a buzzing or humming sound?if so bad water valve located in the back where the hoses connect to the washer or the water shut off is off in the house and no water going to the washer.the model number you sent is to long,after the 110 it should have 8 more numbers and that's it.
Jul 12, 2014 | Kenmore 22422 Top Load Washer
I have a GE Harmony Profile top load washer. It is stuck on filling during the rinse cycle. It usually stays at 18 minutes for about 15-20 minutes. I usually start adding buckets of water to get it going....
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
Nov 10, 2017 | GE WPGT9360EPL Top Load Washer
Washer will not fill in auto can force it to fill why
MAKE SURE YOUR WATER LEVEL HOSE HAS NOT COME LOOSE(ON TUB,AND INSIDE TOP HEAD)IF THATS GOOD THEN YOUR WATER LEVEL SWITCH IS BAD,LET ME KNOW-MIKE
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER
 disconnect the water inlet lines that attach to the back of the washer and see if the screens are full of sand. sometimes sand or dirt comes thru the water lines clogging up the screens in the washer. try to clean them without taking the screens out of the water valve.
Jun 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
