Question about Epson Stylus C43SX InkJet Printer
Doesnt print the document
I have epson stylus c43sx. i have new cartridge both balck and colored but my printer doesnt print the document i want to print. although it prints, its just printing numbers but not the document i want to print. the ink levels on properties doesnt show the i have a full ink cartridge as well. pls i need help!
  • sarj_88 Apr 02, 2008
    i have epson stylus c43sx. the ink levels on the properties does not show the current levels of my ink cartridge. what's wrong with it? pls i need help
  • ake81973 Jan 17, 2009
    I have C43sx printer ,the blue ink doesnt show in the printed document and also when i run the print test for all the colors the blue ink is the only one not present in the paper and when I changed the colored T 039 (my back up cartridge) the same problem occurs no blue ink printed. how can i solve this.....pls.help.
When i am giving print contnues suddenly printer stoped. what i con do.
Posted on Jan 23, 2009
Hp3420 printer driver
Posted on Mar 05, 2008
Although the cyan prints on a test print it is not
Epson Requires Genuine Epson Cartridges. !!!!!!!!
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 23, 2010 | Epson Stylus DX8400 All-In-One InkJet...
My epson stylus c43sx did not installed or not found
If you are just looking for a basic inkjet color printer for your term papers, or resumes, then this might work fine for you. This uses T038 ink cartridge for Black and White, and a T039 for colored.
However, if you are doing printing most of the time, you might want to invest in an ink-saving printer. This one, from my experiences, empties my cartridge so easily, especially the colored ink.
Other good feature of this printer is you can choose from five print modes. Draft, lets you print speedily and is useful if you just want too transfer some long notes from your screen to a paper. The print is quite thin like a dot matrix print and uses very little ink, but it is quite readable and clean.
Dec 04, 2009 | Epson Stylus C43SX InkJet Printer
Inability to print with epson stylus c43sx just got given
The information is not being sent to the printer.
Check that the printer is set to default (has a ticl next to it) in Start/Printers and Faxes.
If your printer does not appear there then disconnect the printer and reinstall the drivers and software. Connect printer when told to by the install program.
Oct 18, 2009 | Epson Stylus C43SX InkJet Printer
Document failed to print
Make sure ur printer are installed to ur computer and u have port.Cheeck first the port.
May 20, 2009 | Epson Stylus C43SX InkJet Printer
Ink Supply Problem
No, the Epson Stylus C43SX design requires that both cartridges are present and working i.e. not empty. If you wish to always print from one cartridge e.g. black, you can refill the empty color cartridge with distilled water and reset it to full. For this you will need a chip resetter (very cheap - see e-bay for example). Do not run with a dry reset cartridge - you'll end up with a damaged print head.
Aug 15, 2008 | Epson Stylus C43SX InkJet Printer
Black 3e ink not printing
try to test the new cartridge;print a test page or try head cleaning in the printer maintenance software.
Apr 12, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
My printer doesnt work at all
try printing documents in notepad... if it worked then reinstall your printer driver. and make sure you have ink.
Jan 08, 2008 | Epson Stylus C43SX InkJet Printer
Epson Stylus color Printer prints strange lines and doesnt use all colors
You can get this sometimes in Publisher programmes, it's a glitch, but also check cartridge alignment. If your not happy uninstal printer driver, disconnect printer and re instal driver first then re connect your printer.
Oct 25, 2006 | Epson Stylus Color 760 InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
179 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
