Question about Sharp AR-M237 Copier
Drum change Hello, I?m a student at a small university in the middle of no where. The drum on our Sharp AR-M237 needs replaced and there aren?t any companies that will work on it. The only one is Xerox, and they refused because it is not their brand. I am pretty handy with fixing things so I got nominated. I am sure I can ?figure it out? but I would rather do it right the first time and avoid getting straight F?s for breaking our only copier. Any help would be greatly appreciated. BTW, is it sometime possible to just clean the drum vs. replacement? If so, what is the best way to do this? Thank you very much! Comment by jman71, posted on Mar 04, 2008 Hi Andy, yes the print quality is very bad. Has pleanty of toner. Then dean mailordered a drum, so I have it ready to go. Just need to know the best way to swap it out. Thank you very much in advance :)
  • jman71 Apr 16, 2008
    Thanks Sharpman! you instructions were very helpful, particularly the codes at the end...never would have figured those out. the drum was pretty easy once I figured out how it came out of the carrier. do you always replace the blade w/ the drum? I only had the drum so I tried to clean the crud off the blade. everything works great. THANKS 100%! :)
  • joan568 Jul 17, 2008
    Sharp AR-200 - need instructions how to remove the toner and drum. Thanks
  • 62 Answers
Ok first their will be a blue screw right aboive where the toner goes in unscrew this remove the dv unit open the left door slide the drum out on the front of the drum there is a plastic piece turn to release the drum then on the top of the drum their are two screw to remove the m/c unit slide it and remove it then two more screws to remove the drum blade.This machine takes ar-271 dr and ar270bl it will also need devlopor at the same time ar-271 dv.Then when done you will need to set the dv pound asrtic clear astric 25-02 start then counter need resetr in 24 5,6,7 and 10. Good luck this is not a job 4 a first timer.
Posted on Mar 07, 2008
Cover door spring replacement
It helps to have a small tool called a spring hook. Other than that it will function if you tape the cover closed.
blog.equipmybiz.com
May 10, 2013 | Sharp AR-M237 Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Jan 03, 2009 | Sharp AR-M237 Copier
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
How do I change the drum on a Sharp AR-M237?
Hi, i assume you have a drum to replace it with?. Can't really clean them as they are very sensitive. Why does it need changing, your copy quality is effected?. It is a faily straight forward procedure.
Let me Know
Andy
Mar 04, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Copier Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
