Question about Vacuums
Eureka Capture 8803AVZ - EXTREMELY loud
I purchased this vacuum in December and have absolutely loved it. It has tremendous suction!! I have been cleaning the filters after every use. Today it started making an EXTREMELY loud noise. The belt is still turning the brush and the suction is still great, but the noise is almost unbearable. I have completely taken everything apart and all parts look good, I can't understand what is causing the loud noise. The only additional info I can offer is that when I checked the belt, it looked fine. It was rather easy to pop back into place and in retrospect, I have never had a vacuum that the belt was easy to pop into place (it did have good resistance though). The belt could be weak after 3 months of use but would that explain the noise???? Any help would be appreciated!! ~
  • 5 more comments
  • 6blessings Mar 13, 2008
    We purchased a new belt and noticed that the old one had stretched considerably. While putting the new belt on we noticed that a piece of plastic that holds the roller in place had also broken and the right side of the roller was loose (the manual says that this part is not supposed to be removable). We ran the vacuum without the belt and guess what??? The motor was quieter. We are going to try and take the vacuum back to Wal-Mart for an exchange. If that doesn't work then I guess we will have to try the warranty repair shop!! Thanks for your help!!
  • jazer98 May 05, 2008
    Exact same vacuum, exact same problem. Ridiculous noise from this vacuum. I'm hoping I kept the box, because it's going back. If not, then it's off to the warranty repair...
  • Anonymous Dec 22, 2008
    We have this - there was a piece of wire that was pulled into the brushroll at the end. It eventually wrapped around the 'axle' of the brush roll and damaged the end of the brush roll so that it made a ton of noise. If left much longer this would damage the brush roll housing.
  • Anonymous Feb 22, 2009
    I am on my second one of this model and not very happy. I was able to return the first one (of course with a few complications) and thought it was just that one....I was wrong. The second one is doing the same thing. I live 300 miles from the nearest service center which told me they had replaced 6 motors just that week!! HELLO!! It is so loud it hurts your ears to even run the darn thing.
  • Anonymous Apr 14, 2009
    Same thing, I can't stand the noise, it is so loud that I can't even stand to use it. It is about 8 months old and it is the best vacuum I have ever had and now I can't even use it. Help!!!
  • Anonymous Apr 21, 2009
    Same problem....my mom had one and already threw it away....now mine is in same condition.....ridiculous
  • gfive May 11, 2009
    I've had this vacuum for about 8 months, and the noise just started. Just like the others are saying, it's so loud I can't stand to use it.
Had it checked for the noise. Motor bearings go out after a few months is what the AUTHORIZED repairman said. Toss it.
Posted on Dec 17, 2008
Purchased this vacuum from Walmart 2 days ago and really liked the design of the unit. Extra long tubing is great feature. However when started up, the unit made an awful noise that vibrated up through into the handle. Either the motor was not well insulated, or the roller bar was vibrating. Took roller bar out and noticed the original belt had stretched quite a lot???? but a replacement was installed that came in the box. I also put blutak (soft pliable sticky product) on each end of the rollers metal brackets (electrical tape or other should suffice, started it up again and voila! normal vacuum noise, no more serious vibration. Just poor design in that area where damping should be manufactured along with better damping of the motor (isolation).
Will see how long this 'fix' will last as well as the new belt installed.
Posted on Apr 29, 2010
The problem is the receiver for the brush roll is slightly loose. The brush roll has a hexagonal shape at each end and fits into the receiver. You will find a very small gap between the hexagonal brush roll and its receiver. To solve this, line the receiver with a thin slice of electrical tape. This will make the brush roll fit snugly and the vibration noise will disappear.
Posted on Sep 30, 2009
    President:
  • 1,673 Answers
Check the brush roll, are the ends ok and turn freely. Other then that, the motor could be what is making the noise. But you have a years warranty on a new vacuum, take it in to a warranty repair shop and get it fixed.
Posted on Mar 06, 2008
    Problem Solver:
  • 9 Answers
Replace the brush roll .the plastic on the edge more then likely broke 23 dollars on ebay...waiting for mine in the mail...also this vacuum says it uses a u belt ..but guess what ...no u belts in walmart so i have 2 use z belts they work pretty decent like but i have to replace quite frequently.
clean the hose the hair in the brush...take out the dust balls on top of the removable dirt canister.,etc......
hoped that helped
kc...
Posted on Sep 27, 2009
Eureka Boss Capture 8803AVZ Bagless Upright Vacuum smells like it is burning
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
Apr 30, 2011 | Eureka Boss Capture 8803AVZ Bagless...
How do I get the suction over to the hand held hose?
Once you detach the hose from the power head, the suction is at the end of the hose.
User's manual:
http://www.eureka.com/service/manuals/80238.pdf
Dec 24, 2010 | Eureka Capture Upright Vacuum Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Eureka Capture Owner's Guide
Eureka Capture Replacement Belt
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
We have a Eureka Capture. The power is on, but
It is possible that you need to clean the filters. I was shocked when I cleaned mine - did you know the foam one is yellow? :o) I just beat it against the outside wall and then patted it with my hand to get most of it out since I didn't have time to wash it and let it dry.
Manual says that if you use floor powders, these need to be maintained more often.
Hope this helps!
Sep 21, 2009 | Eureka Capture Upright Vacuum Vacuum
Vauum and loud noise
Euther you have a clogged hose or the dirt inlet by the brush roll is clogged, or the motor is bad, But if you have only used it 4 times, and you bought it new, it should have a years warranty on it. Take it to a warranty shop to have it repaired under warranty.
Mar 09, 2008 | Eureka Capture Upright Vacuum Vacuum
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Vacuums Logo
3,704 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
