Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Generic problem for all Sharp Standard Televisions
Does the TOSHIBA TA8445K Vertical Def...
Humanpixels on Mar 05, 2008
Comments:
Mar 05, 2008
Vertical deflection circuit in Sharp television model no. 21V-W99
Aug 15, 2008
- Please speak in English, ruben. Thank You.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 15, 2008
Not Rated)
ruben_148_2
Rank: Apprentice
Rating: 0%, 0 votes
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Was this helpful?
Yes
No
Related Problems
I have a good picture But it is too green. Is there an...
we have a 65 inch mitsubishi it turns off by itself can you...
Hello! We have a Sharp 32c231 TV. The other day we turned...
I have the set apart. I can't find the On-Off switch....
Can you Help with these Standard Television problems?
Can't get clear picture on my...
Solve
No matter what I try the picture quality is poor for any non HD channels on my tv.
Bought a 27 in. Sansui STHD tv...
Solve
Bought a 27 in. Sansui STHD tv hooked it to my cable & box programed tv code so i could... (More)
cc is on and wont turn off
Solve
My tv says it is locked, I need code??????????/what code ? 4 digits?
Sponsored Links
Describe your TV problem:
Select a Category:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Standard Television Experts
Top TV Repair
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
