Question about Maytag Neptune MAH5500B Front Load Washer
PF display on my maytag neptune
My neptune started to fill with water and display reads PF and i can't find my manual to see what problem is- any thoughts?
my power just surged (cut off and on) during a storm and I was in almost finished washing a load of clothes... 13 minutes remaining but the got a PF code. is there a reset or what?
  • 1 more comment
  • 3dirtyboys Mar 05, 2008
    Thank you! Actually, I just left it overnight & this morning I pushed start & the door locked and unlocked, but then it started to rinse & finished out the cycle.
    You'd think the solution would be listed simply in a troubleshooting guide in the darn manual. It would have saved me a lot of trouble- now the clothes my boys needed for school are barely going to be dry for them to put on! That will teach me to wash all their jeans and boxers in one load! Also, I spent a good while online trying to find out what to do & from what I was finding I thought I'd have to call for service!
    Thanks for taking the time to help out... too bad I wasn't awake at 0330 when you posted that- the boys clothes would be nice and dry by now!
    I'm in the market for a new set- full size stackable.... any recommendations? My appliance store recommends the new "Duet"... comments?
  • Anonymous Jan 27, 2009
    I also had a power surge and have the same PF in the display.
  • Anonymous Feb 12, 2009
    What does the PF code mean and how can I make my washer work?  It has standing water in the drum.
The poster who advised me to unplug the unit for about 5-10 minutes was likely right and I probably could have done that and been able to restart the cycle last night but I waited until this morning and just selected "rinse" and pushed start. The door locked, then unlocked and the cycle stopped... BUT... then it started draining & finished correctly.
Chrf's assistance was definitely helpful- wish I'd been up at 0330 to try it because waiting all night for it to 'rest' on its own certainly messed up the clothing situation for my boys this morning!!
great website- thanks for being here!
Posted on Mar 05, 2008
    Problem Solver:
  • 8 Answers
It stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
  • chrf Mar 05, 2008
    hello 3dirtyboys, hopefully a little cleaner today. i can understand as i do auto repair, home and a/c repair. sometimes i think i am a dirt magnet. as far as recommending a newer unit, i am not very familiar with most of the newer brands, but i have a friend who is, ill ask him and get back to you. i can tell you this, my mom has a kenmore thats about 12 to 15 years old that has had only 2 problems. the timer burned( some of the points inside it, which i repaired ). a new one would have cost $75. also the pump clogged which i also fixed by taking it apart and removing the hair...just about anyone could replace timer or clean pump with a little on line guidance. anyway, have a good one. ill try to get back with more advice in the next few days or so. chrisfrost@cox.net
Maytag MD5500 displayed a code PF. what does that mean?
Power Failure maytag whirlpool same same:
http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
Apr 17, 2011 | Maytag Neptune MDG5500AW Gas Dryer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune dryer won't start. keeps trying and stopping. flashes PF on the display
neptune dryer has 8.8 on display and won't clear. How do you clear this?
Apr 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune Washer
Excellent, glad to hear we could help.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hi liz PF on display means Power Failure...One of the components powering the machine is damaged...Do u know how to use a voltmeter?Do you have some knowledge abt electricals?IF YES report back..If not call a technician..You will need to check the power circuits around the motor section to see whats wrong..
Nov 03, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,574 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
