Question about Acer NSK8458AN Keyboard
Keyboard stuck in upper case
The keyboard on TravelMate 2310 is stuck in upper case and will not type lower case.
My portable keyboard plugged into this laptop types properly.
Thanks for your help
Ann
  • 2 more comments
  • Ann Tasker Mar 05, 2008
    No, The caps light is not on.
    but, There is a small green light illuminated, 2nd from left beside the unlit caps lock light and I don't know what it represents.
    I tried to clean keyboard with a small brush to no success.
    I appreciate whatever suggestions you have. Tbanks again, Ann
  • Anonymous Mar 14, 2008
    Function key for certain keys is locked on. The lock light on the far left plastic cover has the second light illuminated and I can not get it off.
  • Anonymous May 06, 2008
    what is function key? my keyboard is stuck and everything is reversed> please< please help! how do you get keyboard back to normal? i tried to reboot _ no help> all punctuation is wrong too because of upper and lower case problem> seems to be stuck on upper case and when i choose upper case (light) i get lower case>>>> please advise asap> Microsoft keyboard and gateway computer thanks
  • Anonymous Aug 27, 2008
    how to undo the caps, they are reversed and the caps light is not on and it's typing in capital letters. please help.
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Posted on Mar 05, 2008
Hi -my acer 2310 was also recently stuck in Function key as described by guest 14/3/08 i managed to fix it by holding down the Function key and pressing F11. good luck :)
Posted on Apr 16, 2008
Thanks sleepytako - that fixed it!!
Posted on Sep 15, 2008
What is an uppercase on the keyboard?
Posted on Feb 24, 2010
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
WHEN YOU PRESS THE CAPS LOCK BUTTON YOU HAVE THE CHOICE OF UPPER AND LOWER CASE LETTERING BUT THERE IS ALSO AN ARROW BUTTON WHICH IS TURNED OFF AND I AM NOT ABLE TO TURN IT OFF IT SEEMS TO HAVE REVERSED MY...
That UP arrow refers to an UPPER CASE letter. If ever you press the CAPS LOCK key, it should turn off, if it does not it means the CAPS LOCK key for some reason is stuck. Try restarting the computer and by then the CAPS LOCK should be disabled.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 | Gateway 2520915 Keyboard
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I have a Yamaha YPT-400. I walked into the music room to find a 85lb. child standing on the keys to get to a shelf above the keyboard. Grrr...Now, I have a key stuck. How would I fix this?
You have to disassemble the case to get to the keys. They LIKELY stay with the bottom of the case. Be careful of the cables from the upper half of the case to the lower.
I am not sure what type keys you have. If these are the semi-weighted piano type, the spring underneath gets out of position... If they are the silicone dome type, the dome may be crushed and you will have to replace the section that is bad. Hopefully the circuit board under that type is not cracked.
The first type mentioned requires some tricks and for that type you MAY have to remove several keys to assemble them in order. I had to make a little "L" shaped piece of metal to get the springs into place. It took about a 1/4 inch leg to go between and under the key to lift the flat spring into place.
One has to get the tang at the front of the key engaged as well. Certain notes you have to install in sequence as the black keys can block getting a white key in position.
Mar 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
How do I fit a replacement keyboard for my acer travelmate 4150
You need to remove the middle cover of the laptop and unscrew a few screw at the lower case. Try the find the logo keyboard at the lower case. I think just this model got screw to remove first to take it out.
Sep 28, 2009 | Acer TravelMate 4150LCi Notebook
Cant type upper case letters
If your caps lock is not working, a best alternative would be to hold down the shift key while pressing a letter and it will convert lower case to upper case.
Sounds like a new keyboard may be in the future for you.
Sep 01, 2008 | Computers & Internet
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Keyboard locked in upper case
Try reseating the key board.
Check whether the keys are stuck especially the shift,alt,caps lock.
Hav you spilled any liquid on the keyboad.
Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
Update the keyboad software from the microsoft website.
Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
You can try holding down function key and press f11.
Control Panel -> Regional and language settings -> Tab: Languages,
Button: Details, and add a US Keyboard.
Check this to know the functions
http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
Check the keyboard settings.
Try using other keyboard to know the keyboard is fine or not.
This will help you i hope.
Good Luck.
Live, Love, Laugh.
Acer NSK8458AN Keyboard Logo
10,726 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
