Question about Brother MFC-3220C Plain Paper Inkjet Fax
I cann't receive any fax.
What can I do? The fax keeps coming but the machine didn't pick it up.
  • homeseller May 16, 2008
    I do not have an instruction booklet for this fax machine.....how do I set the printer to receive properly?
    Problem Solver:
  • 12 Answers
First thing to check is to make sure all the lines are plugged into the correct slot. After you check and make sure those are ok try and get another fax to be sent to it while you are there and after it rings, press the 'HOOK' button and see if it receives the fax and starts printing. If it does, more than likely the printer is not set to receive properly. If the 'HOOK' button doesn't do anything then the modem in it is bad and has to be replaced. Unfortunately, its not cost effective to replace those. Its cheaper to buy a whole new printer and get the 1 year warranty.
Posted on Mar 28, 2008
4 Suggested Answers
SOURCE: Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Posted on Jan 24, 2007
Healeyman
  • 1198 Answers
SOURCE: My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Posted on Apr 27, 2009
M2Tech1
  • 313 Answers
SOURCE: Fax machine won't receive without pick up phone receiver.
on the front display you will see a recieve button and you need to press this and you will see on the display it say either fax...fax/tel.. auto press the button until fax shows thsi means it is only being used as a fax so the line will auto pick up... if you set it to auto it will ring check the line and if it finds its a fax it will put it through as one if not it will ring you phone.. good luck
Posted on Jun 26, 2009
Our brother intellifax 4750e fax machine will not
It is probably set to manual receive, meaning you have to pick up the receiver, then hit start to receive the fax. I'm sorry I don't know specifically where to find this setting on your model but if you can find it in your menus, you should be able to switch to auto receive to eliminate this.
Oct 15, 2009 | Brother Office Equipment & Supplies
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
The fax picks up every call
Most fax machines are set-up to pick up all calls. There isn't a way to know you are receiving a voice call until the fax picks up and doesn't hear the tracer signal that kills our human ears.
You could change the number of rings it takes the fax machine to pickup the call. If you set it to the max, you would have plenty of time to pick-up. this option is normally part of the settings on the machine itself.
The only other options are to unplug the fax when you aren't expecting to receive a message, or get a dedicated fax line. It depends on how much you use the fax.
Hope this helps! Please don't forget to rate the answer!
Jan 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Can not receive faxes
On the front of your machine, you will see a button that says "In/Out". I bet someone hit that by mistake, turning off auto-answer.
Nov 05, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax UF 7000 Fax Doesnt Receive
These fax machines have a problem with memory.You may want to add extra memory cards to them.Either that or you have to keep manualy emptying it out.Memory usualy comes in 8&16MB.
Oct 18, 2007 | Panasonic Panafax UF-780 Plain Paper Laser...
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-3220C Plain Paper Inkjet Fax Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
