Question about Logitech diNovo Media Desktop 9673120101 Multimedia Control Panel
Mx900 mouse not charging on base
The mx900 mouse is not recharging itself when placed on the base. The red led on the mouse stays flashing and does not turn green. Contacts have been cleaned and the base does work (bluetooth reception)
  • Anonymous Mar 16, 2008
    I have the same problem. The mouse charge led continues to blink red instead of switching to flashing green to indicate that it's charging. There is also no connection with the hub as the hub won't connect to it even after replacing the batteries. This has happened before and removing the batteries for a certain amount of time and then following a specific procedure fixed it. Unfortunately I don't remember what. Anyone have any ideas?
  • Anonymous Mar 17, 2008
    Looks like it's waranteed for 5 years. Check out http://logitech-en-amr.custhelp.com/cgi-...*em*RT-i&p_lva=3219 From their forum it sounds like their returns policy is pretty good!
5 Suggested Answers
  • 38 Answers
SOURCE: Flahsing Red Light
Now what you have to do is look for a reset button on your mouse and your wireless mouse signal receiver.
When the receiver and mouse both are on press the reset button on both of them one by one.
This should solve the problem.
Posted on Jul 17, 2008
SOURCE: mouse
I cleaned the terminals on the charger and the mouse using a little rubbing alcohol. This solved the problem right away.
Posted on Jan 12, 2009
  • 6 Answers
SOURCE: Stopped recharging
get a new pencil..........use the eraser to clean terminals on mouse and stand/ please be gentle
Posted on Nov 29, 2009
mcdevito75
  • 1970 Answers
SOURCE: recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Posted on Jun 29, 2010
I have a wireless mouse logitech mx700 that i have had for about 3-4 years. now when i set it on the charging module dock, the green light does not come on, indicating it is charging. do the rechargable...
First try unplugging the charging base and using a Qtip and a light amount of rubbing alcohol(because it evaporates) to clean both charging surfaces:
The 2 gold colored medal plates on the bottom of the mouse and the 2 prongs that touch them on the base. Wait about 15 minutes to make sure all rubbing alcohol has evaporated. Plug the charging base back in and see if its working. If it didn't seem to help, you can easily change the re-chargable batteries in the mouse as they are just 2 re-chargable AA batteries. Make sure they are replaced only with "re-chargable" batteries only. Replacing them with non-rechargable AA batteries can cause them to explode if placed upon the charging base.
Nov 22, 2017 | Logitech MX700 CORDLESS OPTICAL MOUSE...
How do i charge it?
You do have re-chargeable batteries in it? You could try a new set of batteries and there's usually a "Connect button you can press to reconnect it after installing new batteries.
Jan 02, 2010 | Dynex Wireless Optical Mouse
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
bartman9@earthlink.net
Mar 17, 2009 | Kensington StudioMouse Wireless
Flashing red light
Most wireless mice will hibernate after a short period of inactivity. If something bumps the desk or moves the mouse it will start scanning again. If you don't like the light, you could try a laser mouse (no red LED flashing).
Feb 08, 2009 | HP Wireless Optical Mouse
"Cyber" brand wireless rechargable mouse
Okay i got the same problem i did everything press the big blue botton and the one on the bottom of mouse and still nothing....
ITS THE BATTERYS!!!! the ones that come with it are shiet i put some tranisonic ones into and it worked instantly the moment i put "good" ones in the red light came on instantly
Aug 23, 2008 | Computers & Internet
Flahsing Red Light
Jul 16, 2008 | Logitech MX 700 Mouse
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Logitech diNovo Media Desktop 9673120101 Multimedia Control Panel Logo
518 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
