Question about Panasonic CT-32HX42 32" TV
Tv repaire i have 32 ; pana. tv. it's picture go out. some time u can here only audio and click click noise no pict. after sometime work fine for 10 to 15 min. start problem again . what should i need to fix / or prob.
My tv we have a vertical line.what should i do
Posted on Mar 09, 2008
I have no sound at all the pict is fine no comp. sound or dvd sound
Likely a audio circuit problem in the set unless somehow the speakers in the set are switched off?
Jun 14, 2012 | Vizio VP322 32 in. Plasma TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
PS32500 32" TV Problem
The sound that you hear is coming from the sound detector not working or not receiving any audio. If the set is set to a second audio (SAP) program this could be you trouble. Some programs are broadcast this way. (such as Spanish for Spanish speaking people. Check you audio program settings.
Stargazer
Feb 19, 2008 | Proscan PS32500 32" TV
Still posessed!
These tv does have loose of audio problems im concern about looseing picture . Try unplugging tv for 5 minutes it will reset tv very common fix for audio. Tv that are less then a year old are sometimes covered under new warr call manufacture on that.
There is a microprocessor on these that lockup and when you unplug it. it resets it.
I have a tv shop and have helped customers get exchanges under a year especially if you complain
good luck i hpe i helped Thanks DOCTOR VIDEO
Dec 31, 2007 | RCA 32V550T 32" TV
RCA 32V550T 32" TV Possessed
I am having the same problem with my RCA 32V550T. This has been the worst purchase I have ever made - it was an expensive TV at the time that I got it and it only worked for a few months. It may or may not come on. It may or may not have sound. It rarely works but If per chance it does come on it will work maybe from 15 mins to 2 hrs. depending on it's mood - yes I think it is possessed. It turns on and off at will. I keep it unplugged most of the time because I worry it may be a fire hazard. I have had it repaired but the problem persists. It's a useless but expensive heap of junk taking up space in my living room. I had a great RCA VCR that I bought many years ago but contemporary RCA products are not the quality they used to be - be smart and stay away from them.
Dec 15, 2007 | RCA 32V550T 32" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
JVC AV-32730 36" picture problem..
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Aug 04, 2007 | JVC AV-32D305 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Panasonic CT-32HX42 32" TV Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
