Question about Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital//Black screen HELPPPP????????
Black screen comes up
all other features seems to work
get the little pictures of camera and tv and such
and little square in middle
but screen is black
tried the setting to tv and couldnt find the shutter speed. hmmm.
any suggestions?
  • 4 more comments
  • donniejoe Mar 05, 2008
    any help appreciated
  • nita kay Apr 13, 2008
    Screen is black when camera is trun on in all setting can't take any picture they also come out black but everything else works. I try turning the camera off and on, change the batteries, check all setting
  • pscengineer Jun 12, 2008
    Black screen, cannot see image through the view finder, cannot find reset. I removedand replaced batteries and memory card to try and reset. no help.
  • jjzny Jun 22, 2008
    I have the same problem. I tried using the TV mode fix and removing the batteries but it did not work
  • alex Sep 03, 2013
    hi i have got the same problem. with some light i have seen all set up and i have tryed reset mre times but not news what i think is the battery not good not enough. so i will try to replace. anycase for some seconds at the start the screen is perfect.
  • alex Sep 03, 2013
    hi i have the same problem, with a external light i have seen the screen setup so i reset totally more times but not news, but i thik the problem is the battery not power enough
Posted on Mar 10, 2008
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
When I turn the camera on and look through the viewfinder, it's black. Also, if I flip open the little screen, it is black. It does show the little icons, but it's as if the lens cover is still on (which...
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
Jan 13, 2011 | Canon PowerShot S2 IS Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
I have no image in the viewfinder on a canon S2 IS but the lcd display works and it seems to work fine otherwise. What are the likely causes?
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
I have the same problem with my Canon S3 IS. I was about to buy a new camera and somehow bumped into this post. I tried this solution twice and it WORKS. Thanks a lot.
Sep 30, 2008 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S1 IS
Canon has a recall for it, regardless of age/warranty status of the camera, contact them.
Sep 20, 2008 | Canon PowerShot S2 IS Digital Camera
Black screen
Piece of junk that took great pictures for 1 year and now shows a black screen. Do not buy any Canon products. We also have one of these pieces of junk at work, now displays a E 18 code. Appears Canon wants to make mucho dollars by producing ****.
Apr 13, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
1,520 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
