Question about Intel Server Board SE7505VB2 Motherboard
Mother board problem
Cpu temp. starts with 100 degree celceus
  • 818 Answers
You need to put a pasta above the processor.
put some pasta on the core processor then with a piece of hard plastic or any other material or with the finger (I discourage others) tries to create a uniform layer throughout the core!, you need also a good fan(2 betters) to create air for a fresh air in your pc.
Posted on Mar 05, 2008
Computer will run for serveral minutes then shut down. I have new mother board, new power supply. i use cpu paste that is new. the cpu fans starts with a roar and then is very quite.
Hi
The initial fast running of the fan is normal, I'm assuming the fan has as 4 pin connector which is the one with thermal control ( fan speed increases as the cpu gets hotter).
Try booting into the bios, in hardware monitor tab, see what the cpu temp is doing and the motherboard temp. Look for any initial overheating. If the bios screen indicates a temperature rise to say 80 degrees within the 1st 3 minutes of booting, then recheck the security of the cpu, the thermal paste used and whether the base of the heatsink is free from pits.
Look also at the power output of the 12v and 5 v etc circuits, make sure they are within 0.5 volts (0.25 is better).
Check the motherboard and connections, in particular, look for blowing capacitors, or signs of arcing that would cause power to earth. You may have a hairline crack in the circuit that is expanding as the board warms up.
Check the ram is right for the board, remove one module at a time, test with it in and out.
Unplug all hard drives and optical drives, see if it boots to the bios and stays on and then replace each in turn.
Check the PSU.. new it may be but it could be faulty
remove the graphics card if fitted and any other slot in cards, test with these out of the computer, disconnect the usb cables from their headers
After that, the issue may be a fault with the switch, the switch wires or a faulty board or cpu.
Jul 22, 2011 | Gateway 505GR PC Desktop
5 socket mother board using 2800+ processor failed. Can i get a compatible mother board.
yes you can! compatible motherboards are cheap and easy to find for the socket 754 design compatible with your cpu. with prices going from anywhere from ~$50-$80. great places to shop include frys electronics, newegg.com, amazon.com and tigerdirect.com. when something like this happens to you its always a good idea to consider upgrading your computer as well you can find cpu motherboard deals anywhere from $100 to $200 with a huge boost in computing power. if you choose to go this route make sure your ram will work on the motherboard you are considering. goodluck
Mar 05, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
CPU runs at 100% a lot of the time, mainly when opening internet files, freezing the system and causing the fan to kick in for long periods. I have removed as many programmes as possible and increased my...
It can be possible that the CPU and the mother board has some conflicts .If all unwanted programs were taken off , the OS was installed fresh, an antivirus was installed and the drivers installed then , the system must run well. If not cross check the CPU and the board as your memory is new. Does the CPU/board support the memory.
You have not mentioned make/model
Sep 30, 2010 | Compaq Computers & Internet
Cpu overheat
Check the heat sink .
Oct 21, 2009 | Computers & Internet
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
Mother board speaker drives not working
You can try looking for the motherboard sound drivers upload , it will be quicker to get a temp job and buy another I found
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Gateway Computer
CVI error is a visual interface error, most likely a graphics card built onto the syetm board. However the motherboards are no longer available but there are a number of ways to upgrade this pc if all else in in good order.Contact for further support
Oct 18, 2008 | Gateway (4000811) Motherboard
Unable to monitor cpu temp in bios. says 65 degrees c all the time
I think 59 is not to hot. perhapas is the correct temperature
mafw1
Aug 30, 2008 | Computers & Internet
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Processor overheating
Hi have you cleaned the heatsink? Also replace the paste on the CPU, also you could try installing an extra fan on the case to increase air flow. Also check that your RAM is seated properly and any other chip and card on your board is firmly plugged in. If all this fails replace your CPU. Regards mistyman
Sep 10, 2007 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
Intel Server Board SE7505VB2 Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
