Question about Krell KAV-300i 2-Channel Amplifier
Fuse at power cord blows
The fuse located under the power cord plug is blown.
I replaced it, and it immediately blew again.
Inside, there are 3 switches which I wonder if they are in the correct positions.
They are set to 2, 1, 2.
Any ideas on what my problem could be?
  • 682 Answers
First check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
Posted on Mar 05, 2008
Why does the fuse immediately blow on my power door locks? how to fix this?
You have a short somewhere in the system. Maybe one of the lock actuators or a switch. To test disconnect all locks and switch then replace fuse if don't blow start with driver door and reconnect lock check fuse see if it blew if not reconnect switch active lock check fuse see if ok. Continue with each door separate using same steps until fuse no good you will have found short. Replace shorted part.
Apr 30, 2016 | Cars & Trucks
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
No power
The outlet that the unit plugs
into... Is it 'hot'? Plug in a known working Table
Lamp. If you have power, the problem is the unit.
Where the cord goes into the unit, locate the Power
Supply. Carefully check for any cracked, blackened,
or broken components. My educated guess is that
a small fuse blew, as did the Metal Oxide Varristor,
which is either a large blue or red disc shaped component
near the power transformer. If the fuse is blown black
inside the glass, this indicates a short, and would require
an Ohm Meter to locate it. If the fuse is blown so that
the element inside just melted open inside the glass,
this indicates an overloaded condition, and would require
that the fuse be replaced with a rating 1/4 amp greater
than the original fuse. Why? because most fuses are
under rated to insure that they will need service to keep
people like me from starving! Trust me on this one.
good luck!
Jun 26, 2010 | Memorex MVD2042 DVD Player
Plugged our 110v Crosley into a 220V current in germany. Blew the fuse. Where is the fuse and can it be replaced? Paul
the fuse is nearly located after the the power cord, yah you can replaced it, but if you power it on again and blown the fuse again, theres a shorted parts..
Jun 19, 2010 | Crosley 4-in-1 Entertainer CD Shelf System
Hello...I am an owner of the Fender Passport PD-500 Sound System
Replace the fuse only once. If it blows right away, then servicing is required as continued replacement will likely damage more inside.
Most of thes have a fuse holder that is a part of the input power socket. There is a little rectangular panel adjacent where the cord connects with a tab that you gently pry out and carries a small fuse. Replace the fuse and re-install the carrier.
These units are very hard to work on due to packaging.
May 30, 2010 | Fender Passport Deluxe 500watt Sound...
Fuse replaced but blows againwhen remote clicked for CT32SL14
This is a problem with the main poiwer supply. It could be simply a shorted rectifier diode or more complex. Without taking measurements inside the set or at least seeing what the condition is of the board, there is little we can do to help. This unit shoul dbe brought to a service shop with a request for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair. Expect to pay $50 or more for the estimate.
Dan
Aug 20, 2009 | Panasonic Televison & Video
Hitachi 50GX30B 50 in. Rear Projection...tv won't turn on since electricity went off & on
I have worked on several of this model for power surge damage. Usually what I find is a blown fuse, a shorted regulator i.c. and possibly a blown bridge rectifier(diode array). On rare occasions you can solve this problem by replacing only the fuse, but if the fuse blows when you plug the set in, you will more than likely find above mentioned parts have failed. The best thing to do is to call a repairman but if you have an ohm meter you can test it yourself:1.Unplug set and remove rear cover.2.Get spotlight and look closely at where power cord connects to circuit board.Small glass fuse will appear black if open usually.Otherwise,test for continuity, or just replace it.3.After replacing fuse plug power cord back in while looking at fuse.If you see an instant flash, fuse blew again meaning you will need to obtain parts in power supply and solder work will be required. That is probably as far as I can take this other than saying that you might first want to look at underside of circuit board to determine if major surge damage has occurred. If it has you will immediately know because it will have burn marks all around a/c power supply. I hope this helps, Russmann.
Apr 28, 2009 | Hitachi 50GX30B 50". Rear Projection...
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
303 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
