Question about Fuji FinePix S7000 Digital Camera
Zoom error when turn on the zoom trys to open makes a lot of nosie the zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Posted on Mar 08, 2008
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Psp stuck on hold
u have to open your psp with the screw driver buy the botton u will see a lot of videos on you tube about this then make like them
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
The car makes a slight rubbing nosie
this is a common thing with a lot of cars with PS if the noie is only auidible on full lock it should never cause any furter problems .if it happens during normal steerimg wheel movement the PS pump may be cavitating and will need to be checked or relaced cheers MAL
Mar 05, 2009 | 1995 Mitsubishi Diamante
Nosie reduction
From point of techinician, the noise may caused by the setting of video gain and other settings by the user and also make sure machanically sound by keeping video heads cleaned and functioning well. Check all the setting to defauld and clean video head by using head cleaing tape for about 5 seconds. see if this helps. -James. For further assistance by email, go to www.camerarepairjapan.com
Jan 21, 2009 | Canon XL2 Mini DV Digital Camcorder
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Dec 26, 2008 | Fuji FinePix S1000FD Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Zoom error on finepixA400 camera
I had the problem with the lens being stuck out. I ended up pressing gently but with a lot of force and it collapsed while making some load clicking noises, I figured that I’d busted it, but I turned it off and back on and it worked great. I know it’s not a great fix but it might work for some of you.
Oct 19, 2007 | Fuji FinePix A400 Digital Camera
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Dec 09, 2005 | Fuji FinePix E550 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
260 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
