Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
"burn in" I have "burn-in" lines where the side bars appear for non-hd transmissions. When watching HD picture screen is noticeably darker inthe mid section (between bars). Also have insect behind glass. Is it possible to get at this area?. Fred
  • 103 Answers
The burn in can't be fixed cheaply.You would have to replace the burnt crt guns.The screen can be removed for cleaning.behind the speaker grill are several screws right below the screen.Remove them and slide the whole screen assembly upward.
Posted on Mar 05, 2008
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
My 32 inch samsung lcd tv has got faint black lines running down the screen ,its nearly 4 years old but i expected it to last longer than that,and ive had sky hd box recently would that have anything todo...
Are these lines on both side of the screen or what location are they in? They can be caused by watching 4:3 television with the black bars on both sides. Watching 16:9 full screen HD wont cause issues with that. If only on the sides there is not much you can do except put a pure white screen on the TV and leave that on for at least 6 hours. This will age the panel a little but in theroy wil even the pixel burn you have to make the lines less noticable. Please take a few moments to rate my answer. Thank you
Nov 18, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Old 53" Mitsubishi Rear Projection - Burnin?
Yes this is burn in and replacing the crts that have the image burn is the only fix. There is no lamp in this set. There are 3 crts and not cost effective to replace them.
Apr 25, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Red Vertical Burn Line on LCD Screen
Try changing the picture setting on the television rather than from the picture box.
Sep 09, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
