Question about Refrigerators
My 2 year old maytag bottom freezer refrigerator suddenly stopped cooling. the compressor clicks of an on but will not engage. the fan is running
The Overlaod and relay is burnt and has to be replaced .I am a appliance service technician i have seen this lots and if that don,t work check the warranty cause the compressor is bad .
Posted on Mar 05, 2008
I have a Fisher & Paykel E522B fridge that has suddenly stopped cooling.....it appears that the compressor is still working but both the fridge and freezer are warm.....as we live in a remote area of...
Check fans in freezer and near compressor. Is compressor running continuously or clicking on and off? If fans are running and compressor is running continuously, your problem is most likely within sealed system. That would require a technician and may not be cost effective to repair.
Sep 23, 2017 | Fisher and Paykel Active Smart E522B...
Kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
This is not my main field of expertise . However, as I see you are not getting more support I can address you to this link. It may help you
goodbye
Feb 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator stopped cooling 2 days ago. Freezer works fine. What is broken? Appliance is four years old. Replaced compressor almost exactly 1 year ago.
Check the fan in the freezer and be sure it's working, isn't blocked by product or isn't clogged with ice. If this fan isn't working the refrigerator section won't cool properly.
Jul 18, 2010 | Maytag Refrigerators
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Freezer/Refigerator not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
oiopi
May 09, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
132 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
