Question about Vacuums
I have a Dirt Devil Vacuum that won't start up anymore. It was working, but then it stopped. The tube got clogged up. Now the tube is unclogged and empty and it won't turn back on. It's also hot on the bottom of it. Help? Blown fuse or what?
    President:
  • 1,673 Answers
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Posted on Mar 06, 2008
My new dirt devil vacuum cleaner. It stopped running and won't turn back on.
If it stopped from overheating because of a clog or restriction somewhere it will start back up after it cools down. If that doesn't take care of it take it to a warranty center.
Oct 22, 2017 | Dirt Devil Vacuums
Dirt devil powerburst isn't spaying cleaner anymore
Hey there Angie, this is Jeremy from Crucial Vacuum,
Sorry to hear you are having some trouble with your Dirt Devil Powerburst. Below I have listed some things you can check on to remedy the situation.
  1. Make sure that the two rubber gaskets are attached to the removable tanks (and seat properly on them).
  2. Make sure that nothing is clogged in any of the tubes or chambers.
  3. Make sure the sprayer is not clogged. Over time soap residue can harder and build-up preventing the solution to pass through.
  4. When you turn on the machine, do NOT spray it. WAIT. Run it for 60 seconds in order to prime the pumps.
  5. If that fails, you can try running a mixture of water and vinegar to try to clean the lines.
You can purchase replacement Dirt Devil parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 25, 2015 | Dirt Devil Vacuums
Do my Dirt Devil have a restart button it just stop running
Hi! No the vacuum doesn't have a restart button, but it does have a thermal protector that will shut the vacuum down when it is overheated. If your dirt cup was too full this will activate the thermal protector sensor. Clogs and dirty filters can cause this as well. We recommend emptying the dirt cup, tapping out the filter and checking the hose for clogs. The vacuum will come back on usually within 45 minutes to an hour. Hope this helps. If you need further assistance don't hesitate to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil
Sep 20, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
Low Hose Suction, Hose is open.
thanks for the clarification.
since the hose in unclogged, the next place to look is in the body of the vacuum.
there is usually a tight turn in the dirt channel in the base. often you can see the clog if you remove the hose.
the next step is to dissasemble the base and look for the clog.
does the motor sound normal?
is the impeller turning at a normal fast rate?.
Jan 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
2,424 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
