Question about GE Profile Harmony DPGT750EC Electric Dryer
The harmony dryer is not heating at all. can you suggest a solution?
    Scholar:
  • 52 Answers
Bad element. Bad thermistor. Also some dryers have a contact switch mounted inside or near the timer. Take apart and clean contacts or just spray some "contact cleaner" inside the timer without having to remove the timer. Many dryers have been repaired by spraying the inside of the timers. There are many open holes in the timer to spray into. Keever
Posted on Mar 06, 2008
G.E. Profile Harmony Dryer heats then won't heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 10, 2010 | GE Profile Harmony DPGT750EC Electric...
What part is needed to fix the dryer when there is
if it's a gas dryer probably an ignitor. electric dryer, the element.
May 22, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 16, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer is running, but no heat
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating!! Harmony dpgt750ec
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, mca0824@aol.com
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Harmony dryer
old...is it getting warm at all? First thing to reset the circuit breakers. Find the linked breakers, turn them off and then back on. If this doesn't fix it, you may have either a bad thermostat or a bad heating element. The back of the dryer usually has a diagram of the wiring. With the unit powered down, follow the diagram with a multi tester.
Dec 17, 2007 | GE Profile Harmony DPGT750EC Electric...
Ge harmony profile dryer
as for a whirlpool lasting longer than a GE or Maytag, or whatever...they are, for the most part, all the same animal. Made by White Industries, once known as White Westinghouse, they produce nearly all of the major U.S. brand major appliances.Take your pick. Buy according to functions you really want, or need; the more gadgets there are, the more there is to go wrong.
Sep 11, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
88 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
