Question about Samsung HP-R4252 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
Samsung hpr4252x/xaa 42 inch plazma has perfect picture in about 8 inches of the middle of screen from left to right.Top 8 inches and bottom 7 inches ; have lines going across,but you can see the picture thru the lines.
  • 1 more comment
  • diamondtv Mar 10, 2008
    tried but ** luck.I got a**ther fix tip which i am going to try.A**ther repair shop in buffalo,told me that the fix was to change both buffer boards. The part numbers are BN96-02034A and BN96-02216A. I am going to order these 2 buffer boards and replace them and see what happens. Everybody keep trying to help one a**ther. With the industry going the way it is, we need all the help we can get.
  • Geeborg Dec 31, 2008
    Diamontv, Did the buffer boards correct your problem? I have same model and had same "good horizontal band of perfect picture but upper 1/3 and lower 2/3 had multicolored lines like very small venetian blinds but you could see picture through them. Definitely, not a burn in issue.
  • Anonymous Mar 26, 2014
    has 44 vert lines 1 inch apart across whole screen top to bottom otherwise pix goog
  • 103 Answers
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Smashed screen
It may still have a warranty try calling the supplier. :D
Feb 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
I have 42 inch plazma no picture
Ur backlight video inverter board is dead.Buy parts like capacitors for replacement with soldering or buy the whole board.Tries these websites.Shopjimmy.com,Partstore.com or Ebay.com.
Sep 29, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Samsung HP-R4252 42 in. Plasma HDTV Logo
899 people viewed this question
Jerry Greenberg
Jerry Greenberg
