Question about Dell E153FPc 15" TFT LCD Flat Panel Monitor
Computer monitor i have a dell 15'' lcd monitor. i wanted to know if i could hook it up to my regular tv as a secound display? i bought a vga to rca converter and it doesnt work.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 848 Answers
Computer monitor
I have a dell 15'' lcd monitor. i wanted to know if i could hook it up to my regular tv as a secound display? i bought a vga to rca converter and it doesnt work.
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1521HSD1 715L1074 PWPC1521XXD1 Dell ADTV1521HSD1 Power Supply Backlight...
Posted on Feb 11, 2015
    Novelist:
  • 138 Answers
I have never tried that but I would say it won't work that way. I have 2 display cards (3 outputs each, VGA, DVI, TVout) and 3 monitors. When I check the driver software and multiple screen function, it shows only 2 output (VGA and DVI) each. I cannot set TV output as a second screen. Even display properties on windows, it shows only available monitor output. I don't think you can do that.
Thank you,
Tan
Posted on Mar 15, 2008
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection http://www.bestbuy.com/site/agptek-vga-rca-s-video-to-vga-converter-box-adapter-switch-for-pc-lcd-monitor/1308798590.p?id=mp1308798590&skuId=1308798590
Sep 23, 2013 | Dell Latitude E6400 Notebook
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
Does the Dell 1503FP 15" LCD Monitor have VGA
Cable Connections On Back of Dell 1503FP 15" LCD Monitor and Computer connect.gif D-sub(Blue colour) is the VGA cable , hence Dell 1503FP 15" LCD Monitor have VGA capability.
Feb 18, 2011 | Dell 1503FP 15" LCD Monitor
Monitor not working with Geforce 9800 GT
The resolution is set too high for your monitor and you have to throttle it down to a lower number.
Apr 09, 2017 | Dell E151FPp 15" Flat Panel LCD Monitor
I have a HP Pavilion a6838F computer and I want to hook it up to my Hitachi 46" Projection TV (Model# 46GX01B). What cables do I need to do this. I want to watch movies, etc. on the big TV rather than on...
Warren:
Your PC monitor uses the 15 pin VGA connection for the output of your PC.
Does the Hitachi 46" have this type of 15 pin female input connection on it?
The problem is that I don't believe your Projection TV will display the output resolution that your PC outputs.
Many newer LCD or Plasma flat screen TV's have the VGA input feature's as they are made for High resolution inputs such as HDTV '1920 x 1024'
Sorry I just don't beleive that the TV will display the quality image you are so used to on your PC monitor.
Blessings,
A/V Media Guy
Nov 20, 2009 | Audio Players & Recorders
Want to know if i can use as monitor
Depending on the Security System, it may have a VGA out. If so, your set. If not, you will either need a converter to change the output of your security cameras (probably RCA's) to VGA., or you can route it through a PC if you have a capture card.
Dec 31, 2008 | ViewSonic VE500 15" LCD Monitor
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Dell E153FPc 15" TFT LCD Flat Panel Monitor Logo
160 people viewed this question
Alun Cox
