Question about Mitsubishi WS-65313 65" Rear Projection HDTV
My Mitsubishi WS-65313 65 inch, Convergence Problem???
My Mitsubishi WS-65313 65'' Has a very clear picture and color.
The picture curves in at the top and bottom in every mode but narrow.
When we change the picture to Narrow it curves on each side instead.
I read on another post from someone else that there t.v. was doing the same thing.
The solution was to pull the cover off and adjust the convergence manually by the dials.
I adjusted all 6 dials and neither of them seemed to fix the problem.
So my question is could it be my Convergence IC's are going out???
  • AngelaC Mar 24, 2008
    I have a Mitsubishi WS 65511 that I brought in Nov. of 03 . My blue convergence does not move left o or right to line up with the center cross hair. As a reult, the blue on the screen creates a shadow. So, I removed the front pannel and manually made some adjustments. I want to have the same adjustment vaules that I had when I first brought the TV. I have the sevice manual. Should I manually put in the information from the service manual before I get the new part or should I do it after the new part is put in? I am not sure what part to order. Do I need HIC-STK 393-110 and if so, do I need one or two. Or do I need a new convergence board? Thanks Angela
  • AngelaC May 11, 2010
    Where do I get original Mitsubishi parts for my TV model WS 65511? thanks
  • 116 Answers
This is a common problem on projection tvs. There are two convergence chips that need to be changed. STK394-250 or original Mitsubishi # 267P173010 (recommended)
Posted on Mar 05, 2008
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I have a Mitsubishi Tv, WS-65711. The colors have
Ur convergence it dead.Must change the convergence ICS.Know how to solders?Buy a convergence kit,use what in that kit.Tries these websites.Tv repair World.com,Tv Repair kits.
Nov 10, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Jun 17, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Picture Convergence WS-65907
TRY NEW CONNECTERS AND INPUTS,,THEN USE THE CONVERSION
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV picture curves
This is a convergence problem and is usually either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Locate the convergence ICs (large black Ics attached to a heat sink and marked STKxxx). Resolder the pins first. If that fails to resolve the problem replace the ICs.
Keep us posted.
Dan
Nov 07, 2008 | Mitsubishi WS-55807 TV
Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
Sep 09, 2008 | Mitsubishi WS-65908 TV
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
1,062 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
