LG Monitor not working
Front LED blinking very fast but no signal from CPU... tried with other monitors and its working...
  • Vinayan Mar 05, 2008
    with any pc's the monitor is not working, so its sure, not a problem related to pc hardware (videocards or graphics) ..the front led is blinking too fast and there is a ticking sound... also there is no display ...
  • Anonymous Mar 10, 2009
    even with out connecting to cpu the same blinkin problem is comin....
    it is the problem with monitor....
    what could be the problem n how can it be resolved?
I m facing the same problem since last year but I have learnt to cope with it. There are two was.
1) Give the supply to monitor from separate socket instead of using UPS Supply. Whenever it starts blinking, just switch off the monitor supply for few seconds and then turn on again. it will work.
2) If the first solution doesnt work out, Lift the monitor carefully and give it some jerks carefully back and forth. This way My display comes , dont know wether it work for you or not. Do it carefully.
Posted on Mar 06, 2008
    Champion:
  • 220 Answers
You really must provide more details if you want a solution.
Try putting on the monitor without pc.If it works it's video card related issue if not a hardware failure in the monitor.
Samir
Posted on Mar 05, 2008
Monitor wont turn on help
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
Dec 05, 2013 | LG FLATRON L1919S-SF 19 inch LCD Monitor
LG flatron T13SH no display with power LED fast blinking.
no video signal - video card broke down or screen resolution is to high
try boot in safe mode and un install de video card
Feb 20, 2011 | LG Flatron Ez T710BH 17" CRT Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Hi, My SONY CPD G420 monitor has suddenly stopped working - the front led is blinking amber. After power cycling the LED stays green for a few seconds before going back to blinking amber. I have verified...
just unplug the signal cable and see if it shows a warning! if it shows then the monitor is in some working condition! this problem mainly is not the monitors problem its the systems problem, it seem as if the system is in standby when u on it right??? it happens when the processor doesn't get supply or it refuses to come on! you will see that the red hdd load led will not light when u start the CPU; just open the CPU and unplug the smps from the board and blow the pins to clean them up and re-fix it and see it will work. if still it doesn't work try some other smps it will work! reply and revert back for more help with a vote!
Jul 24, 2010 | Sony CPD G420 19" CRT Monitor
My monitor has blanking led blue also when not is connected a graphic card and the monitor does not turn off
if i want turn off the monitor it does not turn off. Connected or not connected is the same while when it was good if there wasn't the signal output the led was orange. Now if there is or there isn't the signal output the blue led blinks
May 10, 2010 | LG Flatron L1715S 17" LCD Monitor
After powered up, no video signal, power led blinking very fast
maybe u have to check ur video card if its is properly attached to the mobo...
Nov 06, 2009 | Computers & Internet
My lg500g 15" monitors green led is blinking contnuously and no display on computer startup
check you video graphics adaptor inside the cpU. or you may try to use another CPU connect your monitor if it is ok their is a problem with your VGA or inside your CPU.
Sep 24, 2009 | LG 500LC Monitor
Powersaving mode
I think your signal Cable is not connected properly.please check. Is your computer booting. Can you see HDD acivity LED blinking in your CPU?
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Jul 03, 2009 | LG L1915S 19" LCD Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
1,089 people viewed this question
Alun Cox
David Payne
David Payne
