Home | Likom | Futura LD5 (White) 15.1 in.CRT Con... | Likom PC monitor hav...
Likom Futura LD5  15.1 in.CRT Conventional Monitor
Problem for Likom Futura LD5 (White) 15.1 in.CRT Conventional Monitor
Likom PC monitor having hi-pitch sound
By ton12 on Mar 05, 2008
my computer monitor produces a head aching, at first with hissing sound then followed by hi-pitch sound in diff wave lengths when turned on for about 5 mins. I already having a migrain. Please help me. I already changed its memory into a bigger size and even reformat my computer but to no avail. So I just turning it off whenever I hear that sound and just be back after 10 min or so and do my comp works... and that sound will be gone for a moment only.
What could be the reason? My cousin suspected that it could be my monitor. Can it be repaired?
Comments:
Mar 07, 2008
- Dear jitenok,
I appreciate your help, but it seems you did not continue or finish the direction on how to fix it. can you give me a step by step procedure please?
thanks again!
Best Solution
posted on Mar 05, 2008
Helpful)
jitenok
Rank: Wiz
Rating: 79%, 137 votes
Yes it can be repaired .check power supply section and sm transformer. change sm transformer.or eht
Comments:
Mar 08, 2008
- there should be drysoldring .plz resolder sm,eht.If it is not work then change sm.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Was this helpful?
Yes
No
Popular Solutions for Likom Futura LD5 15.1 in.CRT
Questions and Unsolved Problems for Likom Futura LD5 15.1 in.CRT
Do you recommend Likom Futura LD5 (White) 15.1 in.CRT Conventional Monitor?
Answer
Answer
envision monitor's brightness setting randomly changes while i use the monitor
Answer
need to configure lcd monitor to play pc games and don't have user's manual and don't know how to... (More)
Answer
It comes on but flatscreen says 'no signal'
Answer
mointor turns off
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Likom Futura LD5 15.1 in.CRT...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 480
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
