Microwave Ovens Logo
Anonymous Posted on Mar 04, 2010
We received a Ge spacemaker microwave oven as a
We received a Ge space saver microwave oven as a gift a few months ago and it stopped woking it makes a humming sound what could it be?
  • Anonymous Mar 04, 2010
    Thank you for your reply.
    The Model number is the following JVM1631WB 002
    Franco
Kelly
Level 3:
  • Microwave Ovens Master 3,740 Answers
  • Posted on Mar 04, 2010
Kelly
Level 3:
Answers
3740
Questions
Helped
2163411
Points
12091
When a microwave makes a notable HUM there are 3 things thant can cause that dreaded hum.
1. Most common failure is the diode
2. Shorted capacitor
3. The Magnetron
If you list a model number I can probably find your parts for you and pass along a couple of trouble shooting tips if your good with a meter.
Kelly
  • Kelly
    Kelly Mar 05, 2010
    HI again Franco. I found your model number. The 2 suspect components are Items 49 and 50 in this link: http://www.appliancepartspros.com/partse...
    The capacitor is here http://www.appliancepartspros.com/part_d...
    First of all before you do anything make SURE power is off.
    Once you gain access to the capacitor "respect it"... they can still bite! While holding a screwdriver well back on the handle, short across the terminals several times to drain any residual charge. A good capacitor will POP 2 or 3 times. Once you have grounded it then use a meter on R x 1,000 or R x 10,000 and touch the 2 terminals with the 2 test leads. The meter should jump.... reverse the leads and the meter should jump again but both times return to the highest reading. / no resistance.
    That brings us to the Diode:
    More often than not this is the culprit that causes the hum.
    Make sure one end of the diode is disconnected and then read across the diode with the meter... reverse the leads and read it again. You should only get a reading in ONE direction. If it is open in both directions the microwave will not work. If it is shorted in both directions the microwave will not work.
    That is it pretty much in a nut shell. Just make sure you test components thoroughly before dashing off to the Appliance parts supply or ordering parts on line. Saves you lots of money!!!
    No matter what GE is going to make sure that you spend at least $50.00 for one of the 2 parts to get you going again.
    Just as a preventive measure I would change item 47 (Fuse) while you in there. The HUM that your hearing has really loaded / shortened the life of your fuse. This is either going to be a 15A or 20A fuse. You can get them mose anywhere they sell fuses. Just match up the numbers.
    Thanks for using FixYa!
    Kelly
2answers
Microwave timer is locked. how do i unlock it?
Press/hold the clear/off button for 3-5 seconds.
Thanks!
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
My microwave is not heating, and the table is not turning.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
76t
GE space saver Microwave not heating
heatman101
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Code on the space between oven and microwave
It's normally about 30", but that info will be in either the installation manual or the owner's manual, depending on the brand you choose.
You mention SpaceSaver, that's GE.
You can download GE owner's manuals and installation instructions here.
Not heating properly
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Microwave dead - what to do now?
Still under warranty so someone is coming to fix it free of charge...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
