Question about GE WSRE5260D Top Load Washer
Wont spin out
Yesterday it was sounding very loud during the spin cyle and it left my towlers at the bottom very wet. Today it wont spin out. I tried unpluggin it and starting it again. Tried spin cyle only..it starts to go and then when it would take off fast, it kicks off.
    Problem Solver:
  • 8 Answers
Are the clothes out of balance? sometimes it can take quite a few trys to rebalance the load. if that is the case, it probably could use new drum springs.
Posted on Mar 05, 2008
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
My whirlpool machine does not spin properly and there is always water left after the spin cycle, when its turned on it will stop after spin cycle like its finished but there is still a lot of water left in...
hi, it sounds like one of two possibilties, will try and help out. The first thing to check is whether the water/drain pump is actually working fine, i think it blocked. Secondly the pump may also be overheating and malfunctioning during the cyle, run it without clothes and check the flow of the drain during the drain/spin cycle and take it from there.
Jun 14, 2011 | Whirlpool Washing Machines
WHEN EVER THE MACHINE IS RUNNING, ESPECIALLY DURING THE SPIN CYLE, THE WASING MACHINE MAKE A VERY LOUD NOISE AS IT ROTATES. IT ALL MOST SOUNDS LIKE IT RUBING AGAINST SOMETHING. ANY...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 18, 2010 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
The washer wont drain or spin and it was making a loud noise during the spin cycle
YOU MAY WANT TO CHECK YOUR PUMP CLEAN OUT.REMOVE THE LOWER PANNEL 3 SCREWS UNDER THE BOTTOM PANNEL UNPLUG THE MACHINE AND LOOK FOR THE ROUND CLEANOUT ABOUT CENTER. THIS UNSCREWS AND PULLS OUT.REMEMBER YOU HAVE WATER IN THE MACHINE THAT WILL COME OUT WHEN YOU DO SO YOU NEED TO USE A WET VAC TO EITHER REMOVE WATER THROUGH THE D-HOSE OR MOVE THE MACHINE OVER A DRAIN. IF YOU HAVE A WET VAC YOU CAN USE IT TO CLEAN OUT THE PUMP WHEN YOU REMOVE THE CLEAN OUT BASKET.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wet clothes after final spin cycle
There are two speed (or three) on most washer motors and what happens is that a motor speed will stop functioning--it will wash the clothes, but the high speed will not function. This also could be the controller, but more likely it is centered at the motor. It the motor is functioning, it coulfd be in the transmission of the machine--which may be the problenm since you heard a loud noise. I am not familiar with your machine, there could be an electronic switch for the transmission to go into high speed as well that has gone bad. I wish I had more direct knowledge of your machine.
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
CANDY CM1612 WASHING MACHINE
dose the drum spin at all please clarify eric
Jan 04, 2018 | Maytag MAH6500 Neptune Front Loading...
GE WSRE5260D Top Load Washer Logo
222 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
