Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57HX81 I have a Toshiba 57HX81. A few months ago i noticed the top of the screen had distortion (vertically....straight vertical lines appeared wavy). It would go away in a minute or two. It has progressed over the months to make the TV unwatchable at first because of the wavy flickering distortion across the whole screen. It takes 30-40 minutes to "warm up" until the distortion is unnoticeable. If you turn the TV off for even a few seconds and switch back on, the top of the screen gets the waves back, although not nearly as bad as the initial turn on. I look forward to any insight you have. Thanks.
  • 1 more comment
  • drinfl Mar 06, 2008
    Thank you for responding to my inquiry. Being a laymen how would I go about adjusting the power supply? I have the repair manual and was unable to locate any data regarding the adjustment of this component? Would there be any other potential components that could allow for my current condition (i.e. capacitor, etc.)? Thank you again for your assistance!
    Regards
    Dan
    Thank you for your suggestions. I had disconnected all attached components with the exception of the cable line. Based on your bullet regarding the cable section, my problem occurs on all stations and as noted in my original posting corrects itself by apx. 95% after an average 30 min. warm up. Any other suggestions would greatly appreaciated!
    Regards
    Dan
    Brigadier General:
  • 6,966 Answers
Hi drinfl,
If I may add and with the indulgence of ser71 and melnavz....
From my understanding, this particular problem is pretty common in some Toshiba models of RPTVs. This could either be a simple voltage double problem or a tricky Hyperboard repair/replacement. Toshiba has acknowledge the problem and has posted a Technical Bulletin affecting repairs. This might be of help to you.
As common also, component and boards are a bit difficult to order and normally takes a couple of months. You may want to try and seek the services of a qualified professional specifically those who are willing to do (and knowledgeable of) component level repair. Alternately, you can also try to have the board/component in question rebuilt or substituted with a comparable replacement (by another manufacturer). Either way, this site might be of further help to you.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 06, 2008
  • Louie  Role
    Louie Role Mar 06, 2008
    Oooops,
    Sorry guys for doubling/tripling ups. Regards to all.
  • Louie  Role
    Louie Role Mar 08, 2008
    Hi again drinfl,
    Any development(s) with your unit?
    Genius:
  • 1,030 Answers
The problem is the hypermodule... JUST repaired one at the shop.. The hypermodule is baisicly the signal processor for these sets.. Toshiba has a bulliteen to service center about this... i am 99.9 percent certain of this The is a cuircit board in this unit that has bad capacitor on it. THe solution is too replace these 11 10 microfared capacitors. very very tricky i would not sugest this for a non tech,, soldering these are hard for experence tech. but it can be fixed. Like i said toshiba has posted this repair to there service tech and works every time
  • Willie Howell Mar 06, 2008
    this is the hyper module with the small caps on it
  • aaron mocco Jan 02, 2011
    where are they in the pic and how do you change them?
    Brigadier General:
  • 3,614 Answers
Look for bad stk's on convergence module. This may take care of pincushion too.
  • micromaster
    micromaster Mar 06, 2008
    The problem was in the convergence amps. stk's.
  • micromaster
    This is not rare toToshiba TV set.
    Sergeant:
  • 279 Answers
If it is due to unstable power, there may be an easier way to fix it that doesn't involve an actual repair to the computer. Power fluctuation's are likely caused by the power coming into the TV - I have that problem at my house. A good way around that is to get a UPS designed for a computer. It doesn't have to be a big one. A true UPS has a battery in it. Whatever you plug into it runs off the battery, and thus gets a steady, very well regulated flow of power. And the battery is constantly charged from the power outlet. If it's power fluctuations causing it, hooking the TV up to a UPS will take care of them.
-Dyllan
    Genius:
  • 1,153 Answers
Sound like convergence problem. Is there anyway you can take a picture of what it's doing and post it here?
    Genius:
  • 1,226 Answers
Hello!
The input voltage of the TV is not stable at start. this become stable when the TV is warm up. Please try regulate your power supply to have the correct supply in onto the TV. else you need the service tech to adjust setting inside the TV. this is sensitive it hard you to adjust by your self. this maybe cost you cheap.
may this help, best regards,melnavz
Posted on Mar 05, 2008
  • Emelio Navaja
    Emelio Navaja Mar 06, 2008
    Continue bro!
    Benimur
    That's your turn, I admit that you are pretty good than us. So keep it up!
  • 818 Answers
As with all products that contain a digital display, in rare instances, when viewing certain content (e.g.. television broadcasts, video games, DVD), you may notice that the sound and picture are slightly out of sync. This phenomenon can be caused by various factors including, without limitation, video processing within the TV, video processing in an attached gaming system, and video processing/different compression rates used by broadcasters in their programming. You may want to try one or more of the following suggestions, which may help to reduce the effect of this phenomenon:
  • If the TV is connected to an external A/V device (e.g., DVD player, video game system, set-top-box, etc.) always try to use the Color Stream video jacks and corresponding audio jacks or the HDMI input (if available on your TV) for connection to such external A/V device.
  • If the TV is connected to an A/V receiver that has a programmable audio delay feature, use this feature to help synchronize the sound to the picture.
  • If connected to a video game system and your TV has the Game Mode feature (see owner's manual for more information), enable this feature.
  • If you notice this phenomenon only on certain TV channels, please contact your local broadcast, cable, or satellite provider to inform them of this issue.
White lines on screen
It is a problem in the vertical circuit of the set---most likely a bad filter cap connected directly to the vertical output IC chip.
It may be a do it yourself repair if you are handy.
Let me know if you have questions.
SD TECH
Jul 24, 2010 | Toshiba 32A33 32" TV
Wavy distortion of the pictures
Hello!
That can be repaired, the vertical and the horizontal that regulate the voltage towards the projection maybe lessen or fulty. you can let the service man/service center repair this. these not much cost you, that is very cheap part and a minimum labor cost.
melnavz
Mar 17, 2008 | Toshiba 50H82 50" Rear Projection...
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
About two months ago when we first turned on the TV there were wavy lines across the whole picture. When it warmed up they would go away. Now, the lines are there almost all the time and it's getting...
hi
You are experiencing a lack of vertical deflection or vertical collapse. Since it will come back the first thing I would suspect is “ring cracks” in the solder joint in the vertical circuit, mainly the vertical IC. These suspect solder joint can be re-soldered and the television set repaired.
I would suggest that you contact a local servicer. If you are repairing the set yourself, be careful, there is always a risk of shock when dealing with electronics.
OR
Check your equipment connections. Disconnect your equipment (VCR, DVD or set-top box) from the TV and reconnect, making sure each connection is in tight.
OR
chek this site,i blieve u will b helpfull
http://www.dshosu.com/how-to-fix-toshiba-rear-projection-hdtv-wavy-lines/
regards
Jul 01, 2009 | Toshiba 57H82 57" Rear Projection...
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
WAVY LINES AT STARTUP
This is a common sympton with those Toshiba projection sets. There is a board inside your set encased in metal shielding called the Hyper Board. There are many small surface-mount electrolytic capacitors on this board and some of them need to be replaced. Replacing surface-mount capacitors on a board that small is no easy task and should be done by an experienced tech.
Jul 24, 2007 | Toshiba 65H81 65" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
327 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
