Question about Intel Xeon, 3.6 GHz (bx80546kg3600ep) Boxed Processor
What will happen if the intel xeon processor will not operate properly
    Sergeant:
  • 300 Answers
The symptoms of a malfunctioning CPU vary. It may have random lockups, blue screens, or restarts. But the most common result is the system will either not start at all or will have an error during it's Power On Self Test (POST).
Posted on Mar 05, 2008
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
Will this set up keep my graphics card and processor cool enough? Will this fan be powerful enough to cool this computer setup, graphics card, and processor? I have the The Nvidia Quadro FX 3500 Graphics...
You're doing good Ben, except you didn't post what I need to know.
Intel Pentium D what?
I need the model number.
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors
Same for that Xeon,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Conroe.22_.2865_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Wolfdale.22_.2845_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
Since the Intel Pentium D uses an LGA 775 processor socket, I just picked out a few Core examples for Xeon's, that do too.
I didn't link them all.
Also I notice that they start with a 1066MegaHertz Front Side Bus.
(1066MHz FSB)
Plus go up to a 1333MHz FSB.
The Intel Pentium D's listed use an 800MHz FSB.
(Unless you're talking about Extreme Editions. They use 1066MHz)
So do I guess your motherboard has an LGA 775 processor socket, and can support processors with Up To a 1066MHz, or 1333MHz FSB?
Just curious.
When I get the exact model number, I can show you precise Thermal Design Point; for each processor. (TDP)
(On Intel Support)
Then it can be determined if a processor fan for a Pentium D, can be used on that Intel Xeon you have.
Off hand looking at both links I gave, I would say yes.
The TDP range for the Intel Pentium D's, ranges from 90 to 130.
The maximum TDP I saw for an Intel Xeon, was 135.
As for the mini-fan on that Nvidia graphics card, if you feel it isn't enough; then suggest buy a better one.
http://www.directron.com/gpucoolers.html
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Single core 2.8ghz xeon to quad core cpu
http://en.wikipedia.org/wiki/Xeon#Prestonia
"In 2002 Intel released a 130nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology, and had 512KB L2 cache. This was based on the "Northwood" Pentium 4 core."
Meaning it is a Single-Core processor.
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29
Scroll down.
400MegaHertz Front Side Bus. (400MHz FSB)
http://en.wikipedia.org/wiki/Xeon#7300-series_.22Tigerton.22
"The 7300 series, codenamed Tigerton (product code 80565) is a four socket (packaged on Socket 604) and more capable ->
QUAD-CORE processor.................."
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Tigerton.22_.2865_nm.29
1066MegaHertz Front Side Bus. (1066MHz FSB)
The motherboard uses the Intel E7505 motherboard chipset,
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#NetBurst-based_Xeon_chipsets
Note the - Processor FSB supported -
533MegaHertz
ONLY supports Single-Core processors, too.
The answer is No
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
Can i put dual core processors in my intel se7505vb2 motherboard?
http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
Free download drivers motherboard intel xeon E5506
Drivers for all Intel products can be downloaded from their website www.intel.com. You will need to know what operating system you are using.
14.April.2014
Sep 19, 2012 | Intel Xeon E5506 processor (2.13 GHz)...
Dimensions
Dell Support > Dimension 8300 Desktop PC > Main Support Page,
http://support.dell.com/support/edocs/systems/dim8300/sm/index.htm
Left-click on - Technical Specifications - in the list.
Left-click on - Physical - in the list.
Height: How tall the computer tower is. Outside edge to outside edge measurement.
Width: How wide the computer tower is. Outside edge to outside edge measurement.
Depth: How long the computer tower is. Outside edge to outside edge measurement.
If you meant Specifications instead;
A) Processor:
Intel Celeron, or Pentium 4, that uses a Socket 478 processor socket.
Either a 533MegaHertz Front Side Bus, or an 800MHz FSB.
(Dell also indicates the Intel Pentium 4 Extreme Edition processors are supported. Too expensive for what you get in return)
http://en.wikipedia.org/wiki/Socket_478
B) Ram Memory:
DDR Sdram that operates at 333MHz, or 400MegaHertz.
PC2700 and PC3200 respectively.
Maximum TOTAL Amount is 4GigaByte
There are 4 Ram Memory slots. EACH slot has a Maximum Amount of 1GB.
C) Motherboard Chipset:
Northbridge chip: Intel 875P. (Part Number Intel 82875P )
(For Intel the Northbridge chip is the MCH, for this particular Northbridge chipset.
Memory Controller Hub)
The Southbridge chip is an Intel 82801EB (Part Number) or Intel 82801ER (P/N)
Commonly known as the Intel ICH5, or Intel ICH5R.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
In the chart go down on the right side to - 875P
Looking across, and at the headings, you can see under the heading - Processors, that there are more Intel processors supported, than just the Intel Celeron's, and Pentium 4's.
Core2 Duo, Core2 Quad, Core2 Extreme, Pentium Dual Core, and Xeon.
Problem is they don't use a Socket 478 processor socket.
All except for the Xeon ( 'Zee-On' ) use an LGA 775 processor socket.
Xeon models use a Socket 603, or Socket 604, or LGA 771, processor socket.
It is just processors that the Intel 875P chipset will support.
D) Graphics Expansion Slot:
AGP
Uses AGP 8X graphics cards.
Regards,
joecoolvette
Oct 03, 2011 | Dell Dimension 8300 PC Desktop
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
I have a Question for upgrading my machine. I havent had the chance to dabble with Dual-Processors.... This will be my first time. Q: Is it possible to utilize a Xeon 2.66GHz x3330 Processor and a Pentium...
You can only mix the same family processors with different stepping and speed. Pentium D is not in the same family as a Xeon. So no, you can not. For as long as the processors are in the same family, you can mix dual core with quad core and even different speed.
Sep 02, 2009 | Intel Quad Core Xeon X3330, 2.66 GHz
ASUS P5Q3 with Xeon CPU
Yes, it will work. However it depends on which one you buy. Here's one that will work with that particular motherboard.
First, visit this website. Now search for, "Xeon" (Without the quotes, though). Click the second result on the list, which should be the, "Intel Xeon E3110 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E3110 - Retail." That processor is a 45NM LGA-775 processor, which Asus claims that motherboard can support 45NM LGA-775 processor.
Let me know if I can assist you further, or if I need to explain anything in more detail. If this solves your question, please rate the solution.
Mar 23, 2009 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Intel Xeon, 3.6 GHz (bx80546kg3600ep) Boxed Processor Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
