Question about Microwave Ovens
I have ants lots of ants in my well water and do not know what to do about them i just filled my tub and have about 300 ants in it my washing machine stopped running cold water i took out the screen and it was packed with ants
  • antwater Apr 23, 2008
    when i run the outside hose, the next time i flush the toilet or run the bathtub, i get a bunch of dead ants in the water when i first turn it on. also the outside hose is always clogged with them. any suggestions? i am trying to sell my house, and this simply won't do.
Let your wife bath first!
Posted on Mar 05, 2008
I have a ge top loader that won't stop filling with water. I have tested the water inlet valve also the magnetic lid switch, water supply hose seems fine. What else could be causing the overflow??
There has to be a sensor or float switch that lets it know when it's full.
Did something happen immediately before the problem started?
Jun 29, 2015 | GE Microwave Ovens
Why wont My Daewoo DWF-750 washing machine not empty water automatically
You've probably got some debris in the pump, or blocking the pump inlet. If you can do this without making a mess (or shocking yourself,) try backflushing the drain hose.
May 06, 2014 | Microwave Ovens
My bosch washing machine is leaving a grimey residue in the drum after the wash. I have tried to run the machine without any clothes to see whether it was simply not emptying properly but that's fine -...
This bosch washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Bosch Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
Not filling up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 16, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Who makes hot water fill washers
Do you mean washers on the washing machine water input pipe?
There is no chemical difference between the red or black washers apart from their colour.
Hope that is what you meant.
Jan 16, 2011 | Microwave Ovens
DRUM MOTOR NOT WORKING TO TURN DRUM. PROGRAMMER OPERATING OK AND ALSO PUMP MOTOR. HOT AND COLD WATER FILLING MACHINE OK AND EMPTYING OK.IT WOULD SEEM TO BE THE MOTOR AT FAULT? THE MACHINE IS 6 YEARS...
Your question was head "microwave ovens" but I think you are talking about a washing machine.
Replacing the motor is a matter of judgement as to the reliability of the machine generally.
If this is the first time the machine has failed in 6 years, then I would have the motor replaced.
If there have been a series of faults, then replace then machine.
(Incidentally I assume that you checked the drive belt).
Jan 06, 2011 | Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
My kenmore he3t washer sometimes fills with water when off.
This can happen if the water inlet valve begins to go bad. The valve has electronic controlled solenoids that open and close to turn the water source on or off. These solenoids go bad from time to time, or the diaphragm inside the valve becomes clogged with sediment and does not close properly.
Another cause can be the pressure switch malfunctioning. The pressure switch determines the water level inside the wash tub and shuts off the water inlet valve when the appropriate level is reached.
Any easy way to determine WHICH component may be causing the problem is the leave the water source turned ON and unplug the washer. If the leak continues, the problem is the water inlet valve. If the leak stops, the problem is the pressure switch.
To access either component, you need to remove the top panel of the washer. Locate the three screws that hold the top panel in place and remove. With the screws removed, the panel will slide back, then lift off. The water inlet valve will be loacted in the left rear of the washer (as viewed from the front). The pressure switch will be in the rear on the right.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the valve.
4. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
The pressure switch is even easier. One connector plug and an air hose is the only thing attached to the switch. The switch is usually snapped in place along the interior cabinet wall with no screws holding it in place.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
I hope I've given you enough ideas to work with in narrowing down the cause of your symptoms. This is generally a very simple repair, that isn't very expensive. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Dec 22, 2009 | Microwave Ovens
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
