Question about Brother HL-2040 Laser Printer
Brother printer keeps whirring away
Probably not picking up paper
    Genius:
  • 3,587 Answers
Probably or definitely..check for paper jams, and then clean rollers
and by the way, get a fresh set of drivers here
Posted on Mar 05, 2008
The printer keeps whirring away.
Is ther a error message and witch light / led is on?
Mar 25, 2008 | Brother HL-2070N Laser Printer
My Brother MFC-685CW has paper, no jam, but the rollers won't pick up the paper when i want it to photocopy. Why won't it pick up the paper - it keeps saying "no paper fed"
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the Multi Function Printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Dec 07, 2009 | Brother MFC-685cw InkJet Printer
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Glossy paper jams
hello! most printers will only print on regular , you can not use glossy paper. the paper pick up rollers will not grab the paper, they tend to skid on the paper, good luck. brother tech
Jan 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Self cleaning and print test sheet
To print a test page, from ready press the go button. There isn't a cleaning page or drum cleaning cycle on Brother printers.
Brothers are notorious for having bad toner and drum issues. They are very finicky about paper quality. What happens is when a lower quality paper is used the higher paper dust and talc gets caught up in the charging brushes of the drum. Brother has no waste sections in their cartridges or drums so the built up junk stays right in the charging brushes and causes the drums to fail. On the toner cartridge side it re-uses it's waste toner adding it back (with the paper dust and talc) into the fresh toner supply area. Eventually the cartridge contaminates itself to the point of causing imaging problems.
Best recommendation after over 13 years fixing printers to you is to use GOOD paper at all times with Brother printers. Brands tend to fluctuate wildly in quality but the most stable brand to look for is a HP (Hewlett Packard) brand paper. They tend to keep the tightest control over paper with their name on it than others I've seen. HP "Office" paper is relatively inexpensive and will save you much more in the long run than buying cheap paper. STAY AWAY FROM STORE BRAND PAPERS OR XEROX 4200.
Hope that helps you.
Aug 11, 2008 | Brother HL 5250DN Laser Printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Mar 05, 2008 | Brother HL-2040 Laser Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
