Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
Last week, my Samsung DLP started to cut off the very top and bottom of the channel display. It's almost like a 60 inch picture trying to be dispalyed on a 56 inch TV. Color and sound still look great and the right and left sides of the display are fine, but channels like ESPN that run a "tickerbar" at the bottom of the screen do not look right. I can see the very top edge of ESPN's tickerbar, but no details. I have tried adjusting the picture size, but the result is the same.
Any advice before I call the service guy?
Thanks in advance...
  • 1 more comment
  • Pointy Head Apr 17, 2008
    I have the same problem on my 61" Samsung DLP. Also the Zoom 1 and 2 cannot be accessed. I'm sure someone hit a button that put it into some mode of some kind that I don't know how to exit. I've read the instruction manual which is the same for several of the different size DLP models, and it doesn't seem to address this in their normal section, or their troubleshooting section.
    Please e-mail me with a solution: BSiegel@tampabay.rr.com
    Thanks,
    Bart
  • bradley_440 Nov 17, 2008
    I am having the same problem with my 42". If you found the solution please email me. bradley_440@hotmail.com
  • daddeats Feb 20, 2009
    mine is doing same - any resolution anyone?
Did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Posted on Mar 07, 2008
NEED TO KNW HOW TO REPLACE NO 2 FAN ON A SAMSUNG DLP TV HL-S50786W
Here is Fan part# BP31-00024A. Search google, find it at various places.
Light engine assembly has to be removed. This involves unplugging various connectors between processing/control chassis on the left side and engine assembly on the right side. Mounting screws on the top and bottom of engine assembly. Then remove light engine assembly completely from the TV. Fan#2 is the lamp cooling fan and is located beside the lamp assembly.
It is not too complicated if you draw a picture of where all the plugs are removed from. If one plug is not put back correctly, unit will not work. Usually a tight fight sliding out the engine. Plastic cable tie-down between the 2 assemblies can be cut and discarded, this makes re-installing light engine considerably easier.
Cheat the cabinet safety switch with tape or stretch connecting wire across it to hold it in "on" position for test after reassembly.
Service cost may be $150-$200 if you don't do it yourself. We do it in most Canada cities.
easyab
Apr 22, 2010 | Samsung HL-S5087W DLP TV
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
White dots on screen
color wheel is failing and this repair cost thousand or more most of the time so i guess it would be better to dispose of or you may get lucky and find one on ebay but make sure you take care in installing
Oct 19, 2009 | Samsung Televison & Video
HL R5087W DLP
try reseating the dvi cable inside the set
Jun 13, 2009 | Samsung HL-S5087W DLP TV
Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Dec 22, 2008 | Samsung DLP HL-P5663W 56" TV
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
331 people viewed this question
Henry  Thomas
Henry Thomas
