Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate pro 750, xp, xfx 630i mother board, esata
The usb2.0 works fine. System does not detect by firewire or esata. i tried differnt cables. hook it up to laptop useing firewire, works fine. not found in device manager or any where else. what can i do to fix this??
  • 74jose Mar 06, 2008
    still need help... yes it has both esata and firewire.
    Genius:
  • 3,587 Answers
Those drivers should be on seagate site, by o/s...make sure you have latest(not what came with disk, by the way)
check your computers warranty here 4 FREE
Posted on Mar 09, 2008
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
1tb Drive flashes, but will not be recognized by computer. Tried on both XP and Vista machines. Not seen by either. Is there any way to remove drive and place inside Vista box?
yes if your system has supports sata drives.
just take out of the case and install in your system.
make sure you have a sata cable.
Have you tried esata there is a cable that plugs into the mother board and goes into a pci blank slot that gives you esata this is the easest way to go
Jan 10, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
Sep 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 50gb external drive - not recog on computer
It could be your USB or firewire. i had a problem with my h drive and now i'm using a ps3 usb cable instead
Sep 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No LAN driver for nvidia 630i geforce 7100 mb
hav nvidia based xfx motherboard GeForce 7100/ 630i. After installing all the driver i found there is no LAN driver. I download driver from nvidia webite but there is no matching LAN driver.
Jun 07, 2009 | Pine Technology Motherboard Xfx Nforce...
Accidentally deleted partition
Simple, Connect your HD and boot computer using win XP CD and try to create a partition again using unpartioned space ! - xome
Aug 21, 2008 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Esata hard disk is not detecting on my PC.Aucs P5 delux board
Is this a new hard drive that you are using?
Once plugged in, you can right click on My Computer and choose Manage. From here select Disk Management under Storage. If the USB or Firewire cable work properly, you will see the drive listed. Here you can Format it and assign a drive letter. Here is the instructions from Seagates website.
http://www.seagate.com/support/disc/iguides/external/engl_qsg.pdf
And here is the link for product support.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Installation_Assistance&vgnextoid=dce3b27d0434e010VgnVCM100000dd04090aRCRD
Nov 23, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freedesktop agent 500gb, not detected on windows xp
I am facing the same same problem with my freeagent 750. It work some time, but most of the time it shows u in My Computer, but cannot enter. Couple of time if you run "chkdsk <Drive Letter>:/R" re-scans the entire hard disk and then it shows up. But that too stopped working now :-) Still hanging around for a resolution.
Nov 12, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
202 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
