Question about Brother HL-2040 Laser Printer
The printer keeps whirring away.
I reset the printer to get the toner yellow light out of the way. Since then it has been whirring away
    New Friend:
  • 159 Answers
F the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Mar 27, 2008
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
Brother HL 1440 won't print
Try first unplugging power, and removing toner
check inside for foreign objects or fragments of paper
Open all doors and close them back , and plug back power.
Sep 04, 2008 | Brother HL 1440 Laser Printer
Is ther a error message and witch light / led is on?
Mar 25, 2008 | Brother HL-2070N Laser Printer
How can you reset a brother HL-5170DN with out the password either with it connected via USB or ethernet i cannot remember my password
You'll need to reset your printer to factory settings. BE SURE TO PRINT A CONFIGURATION PAGE FIRST.
VIA THE PRINTER CONTROL PANEL
  1. Switch the printer off.
  2. Make sure that the front cover is closed and the power cord is plugged in
  3. Hold down the Go button as you switch the printer on. All the LEDs light up. Keep the button pressed down until the Toner LED lights. When the Toner LED lights, release the Go button.
  4. Hold down the Go button until the Yellow Status LED lights. When the status LED lights, release the Go button.
  5. When all the LED's light, the printer will start warming up. The print server has now been reset to its factory defaults.
Nov 02, 2009 | Brother HL 5170DN Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
Afico 3235
SC Waste toner full
Empty the waste toner, it shoukd go away. Look on the right rear side there should be a door, inside should be a big white plastic container 3/4 full of toner.
Sep 05, 2008 | Office Equipment & Supplies
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner and Drum Display Reset
After replaceing the drum keep front panel open while holding down the go button. Once all lights turn amber release go button.
If you close the panel the reset does not work.
Sep 14, 2007 | Brother HL 5250DN Laser Printer
Brother HL-2040 Laser Printer Logo
222 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
