Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidare Our frigidaire makes a noise like something is cutting on and running then it shuts off...lasts for 10-20 seconds...It was doing this for a few days then opened freezer door and all the ice from the icemaker was melting. Also the right side was not cold....I unplugged it...cleaned all the coils in the back, cleaned and took everything out of frige and plugged it back in...It does the same thing...you can hear the fan running inside the freezer....hear the noise in the back coming on and goingoff ....Also when i plugged it in the fan next to the condensor worked good also...alll the lights work good...etc...Please help. its only about 5 years old.... Don
  • slaver Mar 18, 2008
    making a noise like cutting on and off ice is melting lights and fan still working
  • Anonymous Apr 01, 2008
    same problem whats up
    President:
  • Frigidaire Master
  • 2,651 Answers
Only 5 years is important, sounds very much like you have a bad compressor, It's trying to start asn cant so it shuts down(therees the noise your hearing. 5 year manufacture warr. so see if you can find your bill of sale. and give manufacture a call
Posted on Mar 05, 2008
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
NEW freezer making a singing/high pitched noise
That will be the expansion of the coolant turning back into gas and perfectly normal.
Nov 11, 2014 | Frigidaire Freezers
Making a squlling noise while drying
have you checked the belt drive? Belt may need adjusting or replacement.
Jul 27, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Frigidare plmb186cc
Good Afternoon Friend,
I understand that you are noticing less noise, after about a second of starting your Frigidaire microwave, model# PLMB186CC. I suggest checking to see if the power level was changed. The blower sound will be different at levels other than "HIGH". As long as it is still heating, there is no cause for alarm. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Frigidaire Microwave Ovens
Front load Frigidaire shuts off
Hello Duff Family - This is AP and I'm happy to assist you!
A shut off issue on your Frigidare washing machine, could mean a number of problems, but primarily a communication error from the main control board or the timer itself may be operating incorrectly. If you noticed a humming noise, it could either be a clogged drainage hose or pump that needs to be cleaned. Potentially, there could be an issue with the door lock assembly. Can you remember any error codes or odd functions prior to this issue? If you can think of anything in particular, please feel free to reconnect and maybe it's something I can help troubleshoot.
Mar 05, 2014 | Frigidaire Affinity ATF6000F Front Load...
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
When the oven is heating or colling noise the fan/blower makes a humming noise but is not working Frigidare cermaic top range model fes365ec
Either something has fallen against oven or the most common thing is for a mouse to climb in there and stop the fan with his body. I know it sounds bad,, but I find that more than not. Good luck with it. If you have any other question please fill free to ask
Oct 27, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Drum turns very slowly,,makes banging noise
You have something in the path of the belt or the belt has come loose. The motor turning the belt may be loose on the bracket. You can slide the motor back some to tighten it.
Jan 25, 2009 | Frigidaire FGR231A Gas Dryer
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
146 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
