Question about Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked all the way through and one of the halogen light protectors also had a whole in the end of it. I called Lowe's they told me to contact you; day of purchase was 3/1/08 in Florence Al. store code # 04810-30108. Ceiling fan bar code 0 2403478512 2. 228365 52" Helix Chrome and Cobolt ceiling fan .I need the lighting fixtures replaced. sales # SO481JH1 1065339. Thank You Tena McGough e-mail teenmarie@yahoo.com or call 256-702-1806
    President:
  • 1,673 Answers
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Posted on Mar 06, 2008
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
My wall ceiling fan's control unit UC 9051T failed. Light switch button does not work. If I replace it with some generic universal unit, do I need to replace transducer located in the fan housing also, or...
First, you didn't say you checked that the bulb worked. Is that burned out?
If bulb is ok, you will have to make sure the switch is matched with the fan (ususally a set of 4, 6 or 8 micro-switches have to be set the same in both switch and fan to be on same frequency of communication - even if you have an exact US 9051T controller).
A whole new fan is not too expensive ($100) and may be best route if you use the fan alot and it is over 7 years old - just an option.
Also, just because the light doen't work doesn't mean it is the switch transmitter that is broken, it could also be the receiver. Call the company on the website below - they will either tell you how to check or you can send everything to them and they will check for you.
http://www.eceilingfans.com/
Sorry for making it so difficult - I hope it is just your bulb.
-Mark
May 05, 2011 | Vacuums
Light bulb will not screw all the way into the ceiling fan socket. It is a new socket and has not been damaged. Is there any lubricant that I might use to solve this issue? What other advise can you...
An auto store will have dielectric grease. Put a little on the threads of your new bulb and it will be easier to remove in the future, too.
Gary
Mar 08, 2011 | Vacuums
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Mar 07, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
Fan is connected into light circuit in bathroom. lights work but the fan does not
fan is either bad or a wire came off inside of electrical box to fan and light. check it out!!
Aug 13, 2010 | Vacuums
How do i change an Alto halogen light bulb
I am sure you worked it out by now, but for anyone else who is looking; the fitting should have come with a suction cap to attach to the front of the bulb like a plunger to pull the bulb out... terrible design!
Jake
Mar 08, 2009 | Alto 302000414 Attix 8 AS/E Canister...
Vacuums Logo
140 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
