Question about Toshiba Satellite 2805-S202 Notebook
Change CDROM on Toshiba 2805 -s 202
Help me!
I change new DVDROM driver for my Toshiba 2805 - s202 but when startup my computer it message : "IDE1 ERROR" and don't boot .
I try change many DVDROM, CDROM driver but nothing..
    Novelist:
  • 77 Answers
IDE 1 is the CDRom (or any optical device attached). IDE 0 (zero) is the Hard drive. So this message is telling you there is a problem with the DVD/CD-Rom, that has halted the boot process. Now you have no choice but to go to BIOS (read startup screen to find the procedure, usually DEL, F2, or F12 keys) and see if the problem can be corrected there (or if not, disable the drive, save change, and try rebooting again). If this is not possible, then you might try booting from an external device (floppy, CD, USB etc) if your system allows that (and if you have the boot software/media). Otherwise, you must remove the drive, in order to regain your desktop (pass the halt stage in boot process). Here is how to remove the CD:
Underneath the laptop, there will be a screw about 4 inches in, on a centyer line direct from the DVD/CD tray panel. Remove this screw. Insert a pin or paper clip (carefully, and STRAIGHT in!) to the small hole next to the CD tray release button. This opens the tray manually. Pull it out to the full open position, then GENTLY pull further, and the whole drive will release from the laptop.
Once you have reached the desktop, you should try to remove the previous driver if possible, via start menu/settings/control panel/system (or r-click my computer and select properties). In system control panel, there is a hardware settings tab. Here you can remove or disable hardware. Try adding a "generic CD-Rom", so the DVD might get past boot process when you reinstall it (later, below).
Now, try to start the laptop without DVD/CD. If it starts normally, your driver change was incompatible, or possibly, in the process of changes you did something that impaired the drive or its ROM (or perhaps needs to be cleaned).
Now try reinstalling the CD Rom drive (no screws yet, just insert fully). If you are still at the same halt, you have cut yourself out of using this CD, unless perhaps tou can reboot with a windows CD while the drive is installed, and let windows detect and install a PROPER driver.
If that is not possible, you need another DVD/CD drive. You can also buy a replacement or cheap older model for testing system at any legitimate advanced PC shop, or many used computer parts stores. Try the drive before you buy, just slide in and mount a CD/DVD. (you may have a special adapter that must be removed from the old OEM drive and attached to new one, and the tray cover may need to be switched to allow the CD to close for testing)
Regardless of the outcome of any of the above, please post your results, and the complete text of the black boot screen here, so I can analyze the problem -or any other possibilities that may be indicated by the post dialog.
Posted on Mar 05, 2008
Toshiba Satellite 2805-S202 DVD rom is shot, any possible cheap solutions?
Go online to ebay, and check out new and used DVD drivers for your make and model.
Dec 21, 2010 | Toshiba Satellite 2805-S202 Notebook
My computer can read cd's but not dvd's the drive is philips CDD5301
you need a dvdrom.cdrom cannot play dvd while dvdrom can play all of them
Oct 29, 2010 | Philips Computers & Internet
The toshiba dvdrom drive (Toshiba MK2546GSX) installed in my sony vaio laptop is set to region 2, which I bought in Ireland. I am now in the Philippines and would like to change the region to Region 3,...
You can change the region code on your DVD player only 4 times, then it will lock on that region permanently.
Please click on this link and follow my instruction for solutions to viewing DVDs from different regions :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Sep 03, 2010 | Toshiba MK2546GSX 250GB SATA 5400 RPM 8MB...
LAN CARD DRIVER FOR TOSHIBA SATELLITE 2805-S202.
Assuming you're talking about the mini-PCI Intel 10/100 Ethernet card that's built in, Toshiba's support site only has the drivers for Win98SE:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1073810429&rpn=PS280U&modelFilter=&selCategory=3&selFamily=1073768663.
This driver can also be used for Windows 98 and ME.
Now, if you're running Windows 2000, you can use the LAN card driver for Windows 2000 under model # 2805-S201. It will work 100%.
If you're running XP, you don't need to install a driver as it is automatic.
Mar 02, 2010 | Toshiba Satellite 2805-S202 Notebook
Can not boot dell 6650 from external dvd
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Oct 06, 2009 | Dell PowerEdge 6650 Server
My Cd-Rom/DVD-rom don't work. It doesn't open any folder. I thought I have problems with drivers: SCSIVAX DVD/CD-ROM SCSI CdrOM DEVICE DVD-ROM SD-R2102 TOSHIBA LAPTOP SATELLITE 5005-S507 THANKS, OSCAR
According to the Toshiba website, the scsi cd-rom/dvd-rom does not require a driver to operate, but the driver for the scsi controller card it plugs into may need to be reinstalled or updated. Visit the following link, and go to the section labeled scsi cdrom/dvdrom. At the bottom of this section there are two links to websites where you may be able to find the drivers for your scsi controller card.
http://sdd.toshiba.com/main.aspx?Path=8100000000220000000100006598000000E7/810000000C58000000010000659C00002C36
Apr 09, 2008 | Computers & Internet
How to Enter BIOS
setup is always F2 on startup..that should get you there, methinks.
got backup for that Toshiba?
Feb 18, 2008 | Toshiba Portege 4010 Notebook
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
Toshiba Satellite 2805-S202 Notebook Logo
378 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
