Question about Canon FaxPhone L75 Plain Paper Laser
Activity memory only has current day instead of
Need to re-print document rec'd about a month prior. According to manuals, mem holds 0-4999 for Transmits and 5000-9999 for Rec'vs for reprinting and then rolls over. If I print Activity report, it only shows current day T & R (about 20 faxes) instead of what I would expect to be pages and pages of activity representing at least a couple months of faxes. Supposedly, you can then reprint any doc by its doc number after printing the "table of contents" activity list.
I have several of these in my enterprise and they all exhibit same behavior.
I'm even willing to consider unorthodox means (attach to PC via USB and hack into memory) if anyone can provide instructions.
Thanks
    Genius:
  • 1,027 Answers
Open the speed dial cover,
press memory reference
press set.
this will print list of all docs in memory.
TO SELECT THE APPROPRIATE DOC.
Press memory reference
press the down or up to select print document
press set
press down or up to select transaction number
use the forward or back to select things like destination of doc
press set
press "star" to print 1st page or # to print all
Posted on Mar 20, 2008
WGNBPW-710 manual, how do you use the mememory? How do change the date.
Do you mean the Walgreens WGNBPW-710 Automatic Blood Pressure Monitor by HoMedics? If so, the manual is available from HoMedics' support page: http://www.homedics.com/instructionbooks/ . In the product list box, scroll down to the correct model. The direct link to the manual is currently http://www.homedics.com//media/documents/homedics/instructionbooks/WGNBPW-710_IB.pdf .
If this is the correct unit, to set the date and time, press the Date/Time Set button with the clock symbol on the top of the monitor. When the hour is flashing press the adjacent + button to advance the hour to the correct one, if needed. Press the Date/Time Set button to confirm the hour and prepare to set the current minutes and press the + button to advance the minutes to the correct time, again if needed. Again press the Date/Time Set button to confirm this time and the month will start to flash. Press the + button to change this to the current month. Press the Data/Time Set button and this will be confirmed. The day will begin to flash and you can adjust this with the + button. Press the Date/Time Set button to confirm the day of the month and the year will flash. You can adjust this with the + button then press the Date/Time button to confirm the current year.
To scroll through the memory, press the Memory button. Each button press will display the preceding reading from the current one. To clear a memory item, press Memory repeatedly until you reach the reading to erase. Then press both the Date/Time Set and + buttons simultaneously; hold the buttons until you see CLA in the LCD screen.
I hope this helps.
Nov 17, 2016 | Office Equipment & Supplies
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
My internal memory is full, or so says the message, but there is nothing IN my internal memory. Help! It will not take pictures.
buy an sd micro memory card and use the external memory instead .. camera internal mems are only made to hold around ten pictures were as an 2 gig mem card will hold around 2000 pics and there very cheap about $ 25
Dec 07, 2010 | Kodak EasyShare M863 Digital Camera
I have a three and one dells 922 a10 printer.it want snd or rec .
Put your document on ADF or Flat Bed, press on 'Hook Button' dail the number, ask for the fax tone, press strat. your fax would be sent to the destination.fr receving choose automatic option in 'recive mode' instead of manuall.
Apr 23, 2009 | Samsung CLX 3160fn All-In-One Printer
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Additional memory installation
you aint gonna get more than 2gig
you can try external mem(usb)
Jan 11, 2009 | HP Pavilion dv6000z Notebook
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Reset date and time on my Southwestern Bell GH5810
Press+hold MEM. "SET LANGUAGE" should be there. Press MEM , and "AREA CODE". Press MEM and "Set T/P". Press MEM "Ringer ON". Press MEM and "DATE/TIME". The "hour" will blink, type the number to set it. Then minutes Then "AM/PM". To swap it press any key, or "^" to skip. Then month. Then day. Then MEM to get to "CONTRAST". Then MEM to get out totally.
Dec 03, 2007 | Southwestern Bell GH5810 Cordless Phone
Storrage on camera
First off did you format ur memory card? Casio only has 3 brands of memory cards they have tested their cameras with....Sandisc, Toshiba, and Panasonic. The exz600 can take up to a 2 GB card from those manufacturers with no problem. I would make sure that your mem card is formatted. If it is, try a different card. If you don't care about the pics that are stored on your internal mem then you can format your camera, put in a new mem card and then format that. You always have the option of transfering the pics to ur computer first before formatting. After formatting make sure you reset your camera also. Format: in REC mode press menu go to setup tab go up to format press right arrow make sure format highlighted and press set Camera will say "busy please wait" Reset: In REC mode press menu go to setup tab go up to reset press right arrow make sure reset is highlighted & press set.
Jul 08, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Canon FaxPhone L75 Plain Paper Laser Logo
129 people viewed this question
old marine
old marine
