Question about Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
47153 Cleaning Glass Door
How do you get between the glass on the oven to clean it?
  • 1 more comment
  • Anonymous Mar 27, 2009
    glass door is grease and foggy and can not clean
  • Anonymous Mar 17, 2014
    Water ran in oven door between glass panel
  • Anonymous Mar 26, 2014
    need to clean the oven door glass. Can I take the oven door apart. It is a Electrolux induction slide in range
    President:
  • Kenmore Master
  • 2,651 Answers
Stains on inside of outer most glass???. the instruction manual should explain oven door removal procedure. after taking off door a few screws around perimeter of door will relase the outer door skin/ glass. giving you acess to clean it. I wouldn't reccomend digging down much further htat that though, too many screws and panels and nonsense.
Posted on Mar 05, 2008
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How to remove glass on oven door for cleaning,zanussi instruction manuals
Oven door glass is not designed to be removable for cleaning.
Jul 19, 2014 | Zanussi Ovens
I have cleaned my oven in a house I have just moved into. but I cannot get to the double glass in the door, how do I clean in the middle of both peaces of glass. There are no visable screws or clips like...
this is all i could find out...
How to clean between the glass panes on an oven door:
  1. Remove the access panel or drawer below the oven door.
  2. Attach a moistened glass cleaning wipe to a piece of coat hanger wire.
  3. Slide the wire and cleaning wipe up through the slots in the bottom of the oven door.
More items...
How to Clean Inside the Glass on an Oven Door ' Today's Homeowner..
or go to this link..
how to clean double glass oven door Google Search
Oct 27, 2017 | Caple C203 Electric Single Oven
GE 1978 Slef Cleaning oven JKP26002wh 3 Layers of glass in door...How do I clean between the glass in the self cleaning aluminum window mechanism?
You will have to take the door apart to get to the glass that needs to be cleaned out. I would not recommend doing a self clean on an oven that is that old.
Dec 07, 2010 | GE JTP75CMCC Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
653 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
