I have a LG front loader washer (WM2277H) that is showing a dE error code each time I try to start the washer. I checked to make sure that the door was clear. Any ideas on how to fix this?
  • richabri Mar 06, 2008
    I unpluged the washer as instructed and plugged it back in after several minutes. After I turn on the washer, select a cycle and then hit the start button, I hear two clicks and the dE error code appears. This is continuing to occur. Any idea what is wrong? Thank you in advance.
    Thank you for the comments. I tried the manual rotation and that did not fix the issue. I have now unplugged the unit and will try again tonight.
    I'm starting to wonder if something could be wrong with the door lock device. This all started after I had a power failure error code PF that occurred while in the middle of a wash cycle. It appeared that it had completed the wash and spin cycle because there was no water in the drum. Instead of restarting the cycle, I turned the unit off. After I turned the washer back on I was unable to open the door to check if the clothes were done. I proceeded to push the door in pull out a couple of times and the door finally released. Note, I did not use excessive force, but I'm concerned that this might have messed up the magnetic door lock. Sorry for the long note. Any thoughts?
    Brigadier General:
  • 6,966 Answers
HI,
if I may add and with the indulgence of melnavz....
Try to reset the the microcomputer of the unit. This would mean unplugging it for a couple of hours even better overnight.
Another thing you can try is to manually rotate the drum a couple of turns.
Additionally, may I pls confirm that the error message is "dE" and not an "LE"?
Hope this be of additionalhelp/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 06, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Mar 06, 2008
    and hi again,
    My initial post is a confirmation of melnavz solution. If it were a "dE" message, have you checked the drain for possible blockage?
  • Louie  Role
    and hello again,
    the drain problem of course can include the drain filter and hose. Pls check for filter clogging, kinks in the hose and similar possibilities.
    Cheers.
  • Louie  Role
    Appreciate the reply back/update.
    Normally, as long as there is no hardware/firmware fault, the system should reset after a couple of hours unplugged. Any errors encountered because of the power failure would be gone and the unit would reset to default.
    If your "forcing" the door to open has not caused any mechanical fault, then there should be no problem. Most designs can tolerate a bit of "rough use" and your previous actions would not be enough to cause any electronic fault except for possibly mechanical mis-alignment if your particular model uses a latch to lock the door in place.
    Nonetheless, will hold off any other diagnosis after the reset (unplug for hours) has been performed.
    Again, good luck.
    Genius:
  • 1,226 Answers
Hello!
Please try unplug it in the wall outlet and wait for a while and then plugin ans switch on the washer. if not work then try to refer to the manual how to reset the setting of the washer.
melnavz
Posted on Mar 05, 2008
  • Emelio Navaja
    Emelio Navaja Mar 06, 2008
    There is no other option on that matter except replacing the panel board of your washer because maybe the circuitboard relay got error. You can do that by yourself or contacting the dealer of your washer to place it for you., melnavz
My lg front loader I close door push start get clicking noise at door switch and code de door error is it the door switch it fell off truck on to door face.
Error code 'DE' means a problem to lock the door.
Check that the door hook goes properly into the hole.
Check that you didn't put a lot of clothes in and these are pushing the door glass (maybe a test without clothes would be best).
Check that the door closes good and there are no broken pieces from the door.
If the problem insists, probably you need to change the electric door lock. Here is a video for your help. Generally, it is a cheap part. If you cannot do it yourself, you need to call an engineer.
LG Washer Front Load Door Switch Repair DE code
Mar 01, 2017 | LG Washing Machines
Why does my LG washing machine model LG16115FD show error code dE please?
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 10, 2014 | LG WD-16115FD Front Load Washer
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
LG WM2277H front load washer isn't draining.
there is a clog somewhere in the drain for sure see the link below
if you think it has been cleared unplugg for 10 minutes and see what happens LG Front Load Washing Machine Error Code OE How To Clear
steer clear of LG as a repairman for a living they have weird problems like this all the time
over computerized with lo grade parts inside from my experiences
Feb 03, 2018 | LG WM2277H Front Load Washer
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
Washer is showing "TE" error even after replacing the thermistor
Try pressing spin speed and soild level at the same time. Is the temperature about 10 degrees C over the the selected temperature? If no, then try replacing the main board.
Also make sure the thermister isn't loose. That could cause your problem.
If the main board doesn't fix it, then you have to replace the heater assembly.
Im actually looking the the service manual your unit as we speak.
May 27, 2009 | LG WM2277H Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
