Question about Kitchen Ranges
Sticking Knob I have a Maytag Performa gas/electric range. Today when I turned the oven on the knob was stiff. It is only getting stiffer as the day goes on and we cook. Any ideas?
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
There is nothing to do other than replacing the burner switch, no rhyme or reason why it goes bad , but there is no adjustment
Posted on Mar 05, 2008
Setting the clock
To set the time, turn and hold the Timer knob to the clock
symbol = and at the same time turn the Adjusting knob left
or right until the clock shows the time of day. Remember this
is a 24-hour clock. Let go of the Timer knob and it will spring
back to the vertical, oven manual setting.
Dec 05, 2012 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Gas smell is strong on Maytag Performa when using the oven.........some times?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 23, 2011 | Maytag PER5710 Performa Electric Kitchen...
My right front burner does not work on low. it does not turn on until you turn the knob to about the medium setting
many burners have safety mechanism that shuts the flow of gas when it is cold. it is there to prevent the flow of gas in the case when the fire was put out by wind or split of water.
you didn't mention if after the fire is lighted, are you able to turn the knob back to low.
Nov 16, 2010 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Performa electric dryer that won't start
you have an open thermal fuse.part no. la-1053,its kinda tough to install,i would recommend a qualified servicer
Mar 06, 2010 | Maytag Dryers
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Bottom oven is not working - I set it but it isn't heating at all. There are no errors being issued, no gas odor. The top oven is working fine
Hi, open oven door, remove last panel, you will see oven burner, check pilot, if you see a small tube, manually strick a match and light it, then turn oven knob to on position, but if there's no pilot tube, then you got electrical ignition, could be faulty thermostat(knob you turn to put oven on) or thermocouple(device where oven burner conected too) could be faulty. but first check your oven pilot, it should be always lighting, sometimes, they get blown out. good luck.
Aug 07, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Hotpoint oven/range
Is it a gas or electric if it is gas take knob off usally in front where it says 150 degrees and up and if you look down the shaft you will see a little screw turn it counter clockwise to turn oven down if it is electric take knob off where it says 150 /250/etc... and look behind the knob in your hand it has 2 screws to adjust the oven temp.
Aug 25, 2008 | Kitchen Ranges
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
167 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
