Question about Acer Aspire™ T180 PC Desktop
Acer Aspire T-180 Memory Upgrade question
Hi, I have an Acer Aspire T-180 desktop. I am currently having 2x 512 unb pc2-4300 cl4 installed on 2 of the memory slots. I still have 2 empty slots available. I would like to put more ram in there. What are my options for the rest of the 2 slots? And what are the item description or part numbers (e.g. in terms of like 512 unb pc2-4300 cl4)? Thanks for your assistant!
  • Anonymous Jun 01, 2008
    i have aspire T180 512mb 160 gb its a 64 amd athlon and i want to upgrade my copmputer to 1gb what i am going to buy and the procedure to do it.
    mr. reyes
  • ferdi_lala Nov 16, 2008
    Well i have currently 1gig i am not sure about the chip set. Its a acer aspire t180 aswell and my goal is like a 3-4gig inside. So maybe 3 1gig's? but then i have the problem is this possible cause the people from acer weren't willing to awnser the question. Also what chips are advised to use?
    You can e-mail me the response (would really want and luv it!)
    E-mail: ferdi_lala@hotmail.com
    Well thanks hopefully you can help me!
Go to any comp.hardware store take your old 512 so they can match slots get a 1gb or 2-3 can only handle 3.5 gbs replace in slots starting with highest first thats all it takes
Posted on Dec 15, 2010
Hi I had a simple question, ok
I hav an Acer T-180 and the RAM is unb pc2-4300 CL4, is it a DDR1 or DDR2?
And how do u knw the difference?
thanks alot
Posted on Oct 27, 2009
    Genius:
  • 1,226 Answers
Hello!
You can buy 2- 512 mb DDR2 memory. It should be the same spec with the two current memory.
Memory should be the same specs and capacity, you insert it to your slot 4-1GIG to maximize, in your setting i recommend another 2-512mb bcoz your current memory is 512 mb capacity.
Not advisable to insert diferent capacity or diferent brand memory bcoz it cause damage to the mainboard and memory also.
Up to 4 GB of DDR2 533/667/800 MHz SDRAM (dual-channel support on four DIMMs)
in your case, you can add more 2-512mb memory, DDR 2 refer to your current memory about about this number. 533/667/800 and follow.
melnavz
Posted on Mar 05, 2008
    Scholar:
  • 89 Answers
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
(apacer 512mb unb pc2-4300 cl4)
go to cmus and set bios restore default
Aug 03, 2012 | Acer Computers & Internet
Memory card won't fit into orange slot
that is a good idea to match the memory cards like matching four tires on same card
a bit concerned about 'forcing ' them into the slots though
May 25, 2012 | Acer Aspire T180 PC Desktop
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Memory Upgrade for Compaq Presario 2580US
no 'coz these two memory card differ in size and slot especially when the mainboard doesn't support ddr2
Nov 18, 2008 | Compaq Presario 2580US Notebook
I want to upgrade memory of my laptop acer aspire 1691 from 512 to 2gb. Can you tell me which one to buy and how to install them. have you got any manual for acer aspire so that I know where to open and...
it's easy to add memory.
Just open the door on the back of your laptop.
You can see 2 slots of memory.
Make sure that you know the type of your memory for your laptop. I believe is DDR (not DDR2).
May 07, 2008 | Acer Aspire 1690 Notebook
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
1,907 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
