Question about Maytag Neptune MDG5500AW Gas Dryer
Heats up for 2 minutes then shuts off.
I have a Maytag MDG5500AAW-
The flame would click on for 2 minutes then it shuts off.
I just change the coils and it still does the same thing.
  • 156 Answers
Ck the flame sencer and make sure vent is clean
Posted on Mar 05, 2008
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Gas Dryer, heats for a few minutes, then flame goes out
Service Manual for Dryer similar to yours will cover disassembly and troubleshooting:
MDG5500
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 12001349
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires, explosion or death by asphyxiation.
Sep 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer starts, heat up than the goes out
Faulty gas valve coils are the typical cause of this type of "cycling". These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If any gas valve coils are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
155 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
