Question about Dryers
Gas dryer not heating up if any heat at all very little
    President:
  • Dryers Master
  • 2,651 Answers
So long as its heating a little, try removin g the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged
Posted on Mar 05, 2008
Dryer tumbles but does not heat up, there is little heat when it tumbles without any cloths in it.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
I have a whirlpool gas dryer mod lgq9030pq1 it has no heat to very little heat
heatman101;';
Jun 29, 2011 | Whirlpool Dryers
Little or no heat
heatman101
Jun 09, 2011 | Speed Queen ADG4BR Dryer
I have a Kenore dryer, model 110.C6549. Everything seems to be working but there is little to no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore 62602 Electric Dryer
The dryer is on but very little heat is generated. The lint trap is clear and the botton is vacuumed.
heatman101
Nov 03, 2010 | Estate TGDS680EQ Dryer
Dryer heats up onl a little.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 03, 2010 | Whirlpool LGB6300 Gas Dryer
IntelliDry Nat gas Model #MDG9557AWQ LITTLE TO NO HEAT ON ANY SETTING
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Maytag Dryers
My dryer flame lights then goes out after a little while. It does this on timed as well as amount dried cycles. Drum still turns but heat goes out. I can usually get it going by starting the dryer again....
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Frigidaire FGQ332ES Gas Dryer
Gas dryer smells like gas heats up a little bit
The most common problem with gas dryers is the ignitor going bad....
heatman101
Apr 05, 2010 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Marvin
Marvin
