Question about Canon PowerShot A520 Digital Camera
E18 error pops up and to make it worse the screen is green and its making a lot of beeps
I was taking pictures with my dads PowerShot A520 Canon Digital Camera and it accidentally fell off my little computer shelf. The lens was bent and I kinda just poked it and it went back in, but when I turned it on the lens started making a flickering noise, and my screen all of a sudden went green, and then it turned off all of a sudden, and when I put the switch to the picture section when I turned it back on, it gave me an E18 error and shut off again. I kept trying to turn it on until I could finally see pictures again and see through the lens, but everything was blurry through the lens, and when I turned it off and turned it back on the E18 error happened again, and my lens completely stopped moving, I dont know what I'm gonna do
  • 3 Answers
Http://blogs.yucs.org/~dwallach/2004/08/canon_e18_error_repair_instruc.html
The better solution is to send it to Canon's service people.  They can fix he problem is the fixes at the above site won't work.
Posted on Jun 10, 2008
2 Suggested Answers
SOURCE: I'm having that E18 problem, and my screen went green, and now my lens stopped moving
ah ok
Posted on Mar 05, 2008
Error E18
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
Here is how the E18 error looks like. You just get a black screen with small "E18" sign in the lower-left corner:
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found at
this link PLS RATE ME FIXYA FOR MY EFFORT
http://www.fixya.com/support/t102982-e_18_problem
Mar 19, 2009 | Canon PowerShot A520 Digital Camera
Zoom
Dear wwgirl:
Your problem initially sounded like a simple lens error (and was). However you now seem to have alsao developed a possible image sensor issue as well. Contact Canon Tech Support at 1-800-828-4040 to set up a repair of the camera.
Hope this helps.
Sincerely,
HeabyDLB
Mar 21, 2008 | Canon PowerShot A520 Digital Camera
Two different Canon A520 problems.
hey guys. there is no solution that you can do it for yourself. the best solution i can give for you is take it to service centre. here in india we get charged nearly 1800rupees for servicing the lens portions.
Nov 21, 2007 | Canon PowerShot A520 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
CANNON A520 POWER SHOT DIGITAL CAMERA
Tab on the camera. E18 is a stuck lens. This is common on this camera. I'm not saying this will fix it, but don't break it.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Stuck Lens, Beeping, Auto Turn-Off
The same thing happened to me. It was my wife's camera so I bought her a new one and planned to send the damaged camera in for warranty repair. I took the batteries out and put it back in the box. About 5 months later, just as I was planning to ship it to Canon, I thought I would put batteries back in it and see what happened. It started working and has worked since. Ron
Feb 09, 2007 | Canon PowerShot A520 Digital Camera
A520 - how to do an E18 repair?
Dec 01, 2006 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
