Question about HP Pavilion ze1210 Notebook
Reboots after every startup after SP2
After reinstalling the recovery disk and updating Windows XP to SP2, the laptop will always reboot whenever you turn it on. Then once it has rebooted it will run normal and show an error that has caused why it happened that you needed to send to Microsoft. But when you click to send it to microsoft, Microsoft says there is no solution as of this time. Any comments?
  • PaulV Mar 07, 2008
    actually when you run the recovery disk, it formats and deletes all files in the hardrive and install the factory default. Without SP2 everything is normal, but once you update the system to SP2 this thing (rebooting) happens. It shows a blue screen which you cannot see what it says because it is very instantaneously and reboots and goes back to normal. Is there a way I can capture the blue screen or check a log file to understand this problem?
  • guymonreal Dec 07, 2008
    I have had the same problem with a ZE1210 fitted with Windows XP Home edition. It appeared after installing Windows SP2. I did clean installs on the hard disk, and replaced the hard disk twice, first with an identical hard drive, then with a new, larger capacity hard drive. I also changed the RAM memory, with no improvement. While booting the computer, the blue page flashes and the system reboots (sometimes 4 or 5 before the desktop appears and the system becomes stable). Each time I get a serious system error message to be sent to Microsoft. After 2 years of upgrades - hoping the issue will be fixed by a patch in Windows - I got December 2008 an answer from Microsoft saying the problem was induced by the antivirus software, but removing Norton Internet Security 2004 solved the problem only temporarily.
    To freeze and read the blue message, you must choose not to have an automatic restart in case of failure in the setup. The blue page message says PFN-LIST CORRUPT. It recommends to disable the BIOS memory options and features such as caching and shadowing. It would be simpler to have an update BIOS but I am still looking for one.
    Also, I found a message from a ZE1210 user saying that the controller will only handle hard drives up to 20 GB. I have installed new 30 GB and 80 GB hard drives, with the problem still there, so the controller, and a suitable upgrade, may still hold the key to the problem.
    As to HP's customer support, I only got a flat statement that the model is discontinued and no longer supported. The ZE1210 is a neat machine, and users are bound to change their Hard Drive some day: HP's support policy is, in my view, unacceptable. HP should get some lessons from IBM on long term support of their products...
    As to Microsoft, to whom I did mention that the problem disappeared if one removes Windows SP2, customer support worked hours on the phone with me from India, but without results. One cannot run SP1 forever, and Windows SP2 and SP3 are needed for upgrades.
    Guy from Montreal
Microsoft hotfix Q317277 causes this problem in the HP Pavilion ze1210 laptop. I had this happen with my ze1210. The way to fix it is to "flash the BIOS". (I won't assume you know what this means -- if you don't know, you're basically going to just replace a set of instructions that the computer follows when it starts up.)
Now, what you want to do first is get the program jbm130.exe from HP's site (as of today, it's at http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob928_1en&lc=en&dlc=en&cc=us&lang=en&os=228&product=86586). Go there and download that file. When you run that program, it's going to ask you to put in a floppy disk to create a bootable floppy that will flash the BIOS. Now, I know the ze1210 doesn't have a floppy drive, but that's okay. There is a way around that. Just format a floppy disk (to format a floppy, in case you don't know, go to My Computer, right click on the A: drive, or whatever drive your floppy drive is, and click Format. You want to do a "Quick Format".) When it's done, run the program you downloaded. It should say "copying sectors" and all this stuff and then close out. If it just closes out without saying a lot of stuff about copying sectors or something, then you probably didn't format the floppy disk yet, or the floppy might be bad.
If you have an external floppy drive that you can boot to, pop that floppy in the drive and plug it into a USB port on your ze1210 and start it up, and boot to the floppy drive. (I'm too lazy to look up which key does that right now, so look it up if you don't know how. I know if you hit F2 when the HP symbol comes up, it goes into the BIOS, and you can set it to boot from different stuff through there.) When you boot to the floppy, just follow the instructions, and it will reboot, and you'll be home free real quick. Once it restarts, if it boots to the floppy again, it's not a big deal. Just take the disk out and restart again and then you'll be done. If you DO NOT have an external floppy drive, read on...
Okay, so you don't have an external floppy drive. That sucks. But hey, neither do I. Now that you're done making that bootable floppy that's supposed to go in the floppy drive you DON'T HAVE, we need to turn that bootable floppy disk into a bootable CD. This is pretty easy. You want to download MagicISO, a program that lets you create bootable images and such on CD or as an ISO (which is an image file that you can use to easily burn a CD, etc.) So install that and start it up. When you do, it will say you can't save ISO images bigger than 300 MB. That's fine, cause we want to make a tiny ISO from that floppy you made. Hit "Try it" and you'll see this window pop up with a ton of stuff in it. Don't panic. Go to Tools, then Load Boot Image. You just happen to have a bootable floppy in your drive, so select "From bootable floppy driver". (I know, they screwed up and wrote "driver" instead of "drive" throughout the program, oh well. The program works, so I don't care that much about their typos.) The thing that said Not Bootable should now say Bootable on the main screen. If it doesn't, then you screwed up making the floppy somehow. If you screwed up, fix it and then move on to the next step.
Now you're ready to save that as an ISO. Hit File, then Save As, and give the ISO image a name. Save it to your desktop (or wherever, just make sure you remember where it is). Now click Tools, and Burn CD/DVD with ISO. A little window will pop up. Pop a blank CD-R or CD-RW in your burner drive, select the drive letter of your burner. For the CD/DVD Image File, you want to select the ISO image file you just made. Tell it what speed it can burn at. (1x or 2x is actually fine for this, as we're barely burning anything on the CD. It'll be a quick burn regardless of what you choose.) Make sure Finalize CD is checked and click "Burn it". Your CD should burn and you'll have your bootable BIOS Flash CD. Label it HP Pavilion ze1210 BIOS Flash to v. 1.30, or something like that, pop it into your laptop, start it up, and boot to the CD. It'll start up and you'll be golden.
Posted on Jan 26, 2010
  • 26 Answers
I see that this question has been open for quite some time, now. Since HP has been relatively unhelpful in this matter, I believe that I have achieved a bit of a work-around for the situation--after much experimentation.
The machine I'm working with has a 60GB hard drive installed, becausethe 20GB stock drive died--taking the OS and restore partition with it. HP refuses to sell me a restore CD/DVD, so I was left to fix this problem myself.
Some may consider this to be a severe way of coming-about a solution, but it DOES work.
Go to http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=86586 and make certain that you have downloaded all of the latest drivers listed there, and applied the latest BIOS upgrade to the Pavilion ze1210. Make certain that you have your COA product code number handy.
Method 1: Obtain an install CD for the retail version of XP Home (SP2), and install, using the product code from the COA sticker on the bottom of the ze1210 system unit.
Method 2: Utilize an OEM restoration CD/DVD for an XP Home (SP2) installation that is designed for the Athlon microprocessor. (I used the restoration DVD for an eMachines [Gateway] W3107 mini-tower system.) Install to the HP and re-boot.
Press F11 to initialize the restoration from hard drive, and allow the process to continue until it hangs at 39/48 of the application restoration process.
Ctrl-Alt-Delete into Program Manager and kill 39/48 and any successive application restoration attempts that hang.
Re-boot and activate, using the product code from the COA on the bottom of the ze1210 system unit.
For both Methods 1 & 2: install the downloaded drivers and patches, as needed; then update your XP installation, including SP3.
Posted on Apr 17, 2009
    Sergeant:
    Champion:
  • 277 Answers
First you want to do is backup your important files and format your hard disk. then install windows sp2.
Posted on Mar 05, 2008
Need recovery disk
you can download it for 4.99 or call compaq service to order
Nov 23, 2010 | Compaq Presario 700 470024-192 Notebook
Computer will not start up After Windows splash screen Computer reboots itself. gives options for safemode, lastknowngood, start windows normally. but when selecting any same thing happens computer...
Hi alizae68,
It sounds like your Windows files are corrupt. My suggestion is to use your recovery disk if you have one, if not use your OS disk and repair windows. They way you repair is to put the disk into the CDROM, and when the computer asks if you want to boot to the CD press any key, Press a Key! Then Window will load certain files, and do it's thing. Go past the request for acceptance using the F8 function key, and then it will look to see if you have an existing Windows program, at that point you can choose to repair the existing windows, Don;t install new or it will create a new location to install to. It won't erase your files. From XP SP2 on windows always creates a backup folder of the old or original OS and stores it for you to access.
After it repairs your system, it will reboot and you should be fine.
Good Luck
Mark
Feb 17, 2010 | Dell (E210882) Motherboard
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything memory intensive it simply flashes a blue screen at me then reboots. Whats more is after it reboots it won't...
Your Operating System (OS) is corrupted.
The best solution to this problem is to reinstall your OS using an OS installation CD.
I would also recomend upgrading to Windows XP.
You can upgrade by simply installing Windows XP on your laptop.
Back up all your data before reinstalling your OS.
Jan 07, 2010 | Compaq Presario 1200XL104 Notebook
My computer after five minutes turnoff and restart automaticaly
there is some problem with ACER laptops. i want to ask you something. did you go to service before for anyproblem ?
Jun 02, 2009 | Dell InspironTM 1501 Notebook
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Laptop
A couple of solutions for this,,,,
First when did you do you SP2 windows updates?
if running XP then you will need SP2 for the devices to function and with the correct informations.
Try this one first and reboot,
restart and test
If not you may have to ....
format this unit and a fresh install will take away all your problems,dont for get the updates for your drivers,
Very staright forward if you got the disk
or a restore from a partition on the recovery image,back up disk?
What OS are you runnig thanks
Jun 24, 2008 | Acer Aspire 3680 Laptop
My comptuer reboots when I isntall the software
If after installing your camcorder in XP, the computer is Rebooting on its own, the you must get a Windows update. This is NOT a Samsung Issue. It is a known Microsoft issue with XP. Run a Windows Update and download the update marked: KB822603, USB 1.1 & 2.0 update. This will fix the issue of rebooting. Reinstallation of device drivers may be necessary.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
HP Pavilion ze1210 Notebook Logo
255 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
