Aircon Compressor problem
I have a Toyota car having problem with it's aircon. The aircon compressor does not automatically works when I open my aircon. It will take minutes of driving before it works. This causes my rpm to soar during the initial driving. What can be wrong?
I wanna know how do you read the terminal of a 5 tr compressor the common , starting and the running i wanna know how to read it
Posted on Jun 25, 2008
    Sergeant:
  • 288 Answers
Im not that familiar with cars, but if this is a new (90 or newer) then the RPM going so high is because the fast idle switch. It does this to compensate for the extra power being used by the compressor, which isn't coming on at first. Is the electric fan coming on for the condenser coil at the same time as the compressor? You should have 2 fans, one is for the radiator water, the other is for the A/C. There are temperature controlled sensors for these fans on some models. Its possible that may have something to do with it.
Posted on Mar 05, 2008
What could be causing loud grinding noise when i switch on aircon? Aircon now not working but only makes loud sound.
Sounds like the bearing or part of the clutch in the A/C compressor has failed, or possibly component on a/c fouling on something due to recent repairs however would be unlikely and probably just a coincidence..
Check A/C compressor turns by hand, should be firm but not make any noises.
Check for fouling components related to a/c compressor clutch.
Feb 12, 2016 | Cars & Trucks
I have a 2004 lancer Es when I turn the aircon on after 15 minutes of driving I cant change the gears the aircon works fine but renders the gears useless and have to turn it off to continue to drive
There is no relationship between the air conditioning system and the gear box in the vehicle.
The engine operates the aircon compressor via the serpentine belt from the crankshaft pulley and if the aircon is operating normally the aircom compressor will not be faulty either.
If you are having problems with the gearbox it has nothing to do with the aircon system. The issue will be with the gearbox itself.
Dec 27, 2015 | 2004 Mitsubishi Lancer
My car a/c does not cool when switched on
Check gas in aircon system, if pressure is correct and gas line is full, replace aircon compressor.
Aug 26, 2013 | Toyota Cars & Trucks
Aircon relay wiring burnt, squeaking sound heard from the compressor. Help? thanks.
Have your compressor check. Squeaking sound is caused by a metal to metal contact. Your compressor bearing needs to be replace, to get it aligned. So that the metal to metal contact will be eliminated. Reload your compressor with refrigerant, before getting it activated. Replace the burnt wiring and the relay. Since a lot of work must be done, it is suggested that you take this to the car aircon service
center.
Nov 03, 2009 | 1994 Nissan Sentra 4-Door
When switched to on, the aircon does not function.
check for power at compressor clutch if power and earth there is ok new compressor required. no power there check relay and fuses swap air cond relay with another one that looks the same in under bonnet fuse and relay box
Jun 21, 2009 | 1989 Toyota Corolla 2 Door
Aircon of my tazz 2000 130 does not click in to start
a/c compressor may have failed run the engine and have a look under the bonnet get some one to push the button and you listen for a click noise no click no compressor got to dealer for repairs
Dec 23, 2008 | 2003 Toyota Corolla
When its hot the aircon is not getting cold
If not low on refrigerant, Things that could be wrong are expansion valve inopt, condensor fan not working or possible bad compressor.
Dec 07, 2008 | 1992 Nissan Sentra 4 Door
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
