My PHILLIPS model #32ps55s321 keeps shutting off; what's the problem
  • 2 more comments
  • Mark Guarino
    Mark Guarino Apr 28, 2008
    For the past decade or so, televisions were designed with a "kill circuit" that'll shut down the tv when particular parts in the set lose value.
    This particular Philips tv is a nightmare to all tv techs' out there...mainly because it is designed with 5 kill circuits....
  • Wolverine197 May 16, 2008
    tv turns on ok and picture and sound are great then 5 secs latter it shuts off and have to wait 10 secs to turn it back on and same thing
  • leebern74 Aug 03, 2008
    Our philips model 32ps55s321 keeps shutting itself off, what's the deal?
  • jairy222 Sep 21, 2008
    same thing here!please help!!!
2 Suggested Answers
  • 30 Answers
SOURCE: tv shuts off 32ps55s321
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
Phillips/Magnavox tv shuts off after a few seconds led stays lit model # 32PS55S321
SDA [Serial Data] line should be checked. It is a skilled job. Best is to contact any expereinced service technician.
Sep 04, 2013 | Televison & Video
I have a phillips mp4 player. How do you turn it off? Otherwise it just seems to keep running even when I take out the headset plug and lock it. So it just sucks the battery.
I believe there is a button on the side where you hold down and that should turn it off, but you have to hold down button for it to shut off, if not that button then try another.
Jan 31, 2011 | Audio Players & Recorders
TV shuts off 32ps55s321, power led stays on.
Your power source has stopped functioning, replace that, and your problem will be resolved.
Jul 19, 2010 | Philips Televison & Video
Tv shuts off 32ps55s321
Jul 14, 2009 | Televison & Video
TV keeps shutting down.
the power relay contacts are burned replace the relay
May 21, 2009 | Philips Televison & Video
Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Apr 13, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 15inch lcd shuts itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Hi, we have a phillips tv. it is about 6 orso years old. within the last 6 months, it has starting going off. you turn it on and it may play 5 or 10 or even 30 or more minutes but it keeps going off. the...
I wouldnt use that service man. If your set is shutting down its most likely do to the shutdown circuitry being triggerd by a defective component. I would recomend contacting someone skilled with phillips model televisions, most sets that play and then shutdown usually have a problem with a single component that is triggering shutdown, a skilled repair man will test the various voltages to determine the cause of the shutdown.
Jun 07, 2008 | Philips Televison & Video
My phillips model # 50P8341 periodically shuts off on its own. When I turn it back on it plays for a little while then shuts off again.
the set is going into shutdown mode. does the power indicator blink when it shuts down. If so how n=many blinks does it blink?
Apr 28, 2008 | Televison & Video
Phillips 43p8341 tv keep shutting off
some of the parts you can find online some you cant.it aounds more like the power supply than anything else
Oct 05, 2007 | Philips 43P8341 43" Rear Projection...
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
Electro Med Services...
