Question about Magpix B350 Binocular
Binocular Double Vision
After being trasported in my luggage by an Airline my brand new Saxon binoculars are giving me double vision
  • 3 more comments
  • Anonymous Mar 11, 2008
    I have two pairs of binocs wih double vision MEADE 10X50 AND TASCO 10X50
  • Pauly52 Mar 11, 2008
    Thanks for the suggestion. The alignment ,or the colimation of the lenses, has been knocked out of kilter by rough baggage handling.What I really need is a DIY Colimation Lesson
    Thanks Anyway
  • ekmols Mar 27, 2008
    I also am getting double vision, the binocular are not expensive enough to warrent repair, but too good to just throw away. I would like to try a do it solve solution if any one any suggestions on what to do
  • Anonymous Apr 11, 2008
    double
  • Palosano May 15, 2008
    I have colimation of the lenses problem too? Is it possible to use one laser pointer or two to help me out correct the lenses aligment?
  • d_traynor May 03, 2011
    An excellent, but highly technical (though readable) description of how to do it.
    Problem Solver:
  • 18 Answers
We can align yur binoculars for your for 25-30.00 plus 5.00 to ship back to you. Some units have handy set screws to make adjustments from outside the unit. Call me, wwwbinocularservice.com
Art
Posted on May 10, 2008
BAGS GET TOSTED ARROUND ALOT TOSSING CENTER FOCRUM LENS, ALIGNMENT OFF.OR JUST WIDEN SPACE,
LOOKING CROSS SIGHTED
Posted on Mar 11, 2008
Yukon Ranger 5 x 42 night vision goggles just stopped working, I put in new batteries, but when I press the ON button the on light, which is red, just flashes maybe 10 times and then all goes black. ???
Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
Jan 29, 2011 | Yukon 28041 Binocular
No apparent exterior damage but now my nikon's have "double vision" clear on each individual tube but doubled vision when veiwing normal. any suggestions?
The prisms have shifted inside of the binoculars. This is not an easy job as you have to make corrections to the angle of the prisms for leaning field and collimation. Two suggestions:
1. If they are under warranty take them to a repair agent.
2. If you want to do it yourself, there are instructions on the web about how to go about effecting a collimation. Too long to go into detail here.
Dec 29, 2009 | Nikon Action Binocular
I dropped them and they are seeing double now they are the xtra-wide bushnell ,how do i get them back in focus
Try grabbing the binoculars in both hands and twisting the body in the opposite direction of the double vision until the images coincide.
Sep 25, 2009 | Bushnell Xtra-Wide (4x30) Binocular
Double Vision Pentax 10x50 PCF III
If you have double vision it is out of collimation (alignment of the optical axis). You need to send this to the manufacturer for repair.
Jul 05, 2009 | Pentax PCFIII (10x50) Binocular
Double vision
take it into an outdoor shop and they can check the mirror alignment, seems that it may have "altered' itself
Jun 22, 2009 | Zeiss Classic B/GA 524013 Binocular
Double vision
I'm assuming you have set the dioptre correctly for your eyes.
Normally this is caused by a collimation error when one (or both) prisms move. This can be by a small amount.
Your going to have to take them in for service/repair to fix this as is not a DIY problem. (Unless of course you have a collimator lying around)
Mar 24, 2009 | Bushnell H2O 13-2412 (12x42) Binocular
Double Vision
Your glasses have had a hard drop or jar- they are out of colluminatiom send them to Deusch Optics in Nevada
Jul 31, 2008 | Oberwerk (OBERWERK1030X60ZOOM) Binocular
Double vision
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Binocular double vision
you binoculars are probobly out of alignment. Having them realigned costs about $100. If the binoculars aren't expensive, you might want to try this yourself. Basically, one of the front lenses is off-center, and you can rotate it in its mount until the alignment is right. (I.e., it's off center in the right direction.) You will need an optical spanner (which Americans redundantly call a "spanner wrench") or an improvised substitute in order to do this.
Feb 12, 2006 | Nikon Action Binocular
Magpix B350 Binocular Logo
2,218 people viewed this question
Top Magpix Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Magpix Optic Expert? Answer questions, earn points and help others
