My Yamaha HTR-5860 Receiver intermittedly shuts off. When I power it back on it can work fine for an entire day. Some days it needs to be powered on up to tem times. It shuts off without any reason and it is getting quite frustrating. Any suggestions?
Heat could potentially cause this as well. Ideally you should have nearly 1 foot (30cm) of open space above the top & about 8 inches (20cm) at the sides (according the the manual) for thorough heat dispersal.
Posted on Mar 05, 2008
You probably checked already, but I would look for a loose connection or shorted wire; e.g. ground wire, hot wire, in-line fuse, etc. If you don't find a problem, then it is probably shorting inside the unit. It wouldn't hurt to squirt a bit of contact cleaner in and around the buttons and knobs while it's off, work the buttons and knobs to work it in, and give it time to evaporate before you turn it back on.
Hope that helps, good luck.
My yamaha htr-5640 receiver will turn on for a sec then a small click and then shuts down....no speakers hooked up....what is the deal?
With the power off, try to disconnect every component and then power on the receiver. If it still shuts down, then it is an indication of an internal error and the unit needs to be serviced.
Regards,
Yamaha Support
Nov 28, 2011 | Yamaha HTR-5640 Receiver
The volume control knob fell off can i buy a new one model htr 5860 yamaha
Sometimes volume controls are held on by an Allen type screw, which can become loose, allowing it to fall off. You should see a hole in the knob if it is. You might need a long thin Allen Key to get it back on.
Otherwise have checked my spares guide (though it's a few years old) and it seems Yamaha might only do their own spares.
Feb 12, 2010 | Yamaha HTR-5860 Receiver
I need the code for a yamaha HTR-5860
Go to the company web site for the remote, there should be code there.
Apr 10, 2009 | Yamaha HTR-5860 Receiver
Turntable
turntables require a special input... I'd check crutchfield to see if there is something they might have to make it work better...
Jan 23, 2009 | Yamaha HTR-5860 Receiver
Is it possible to play my ipod nano through my Receiver?
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Jan 02, 2009 | Yamaha HTR-5850 Receiver
Htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Feb 22, 2008 | Yamaha HTR-5730 Receiver
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
202 people viewed this question
 Grubhead
Grubhead
